12:1 CR... What starter?
I did a few small things, installed nitrous, hid some wires, etc... Went to load the car up on the trailer for a tune... No go.
The starter gear shoots out like it is going to start but doesn't turn the motor over.
We took the starter off and put it straight power/ground and it shot out and spun. I don't think this means that the starter is good though??? If it does, it would make me think it was a bad ground/etc somewhere... However, only one ground was removed and I have double checked it, it is good. The battery is also good and was swapped for another one.
What are you high compression guys running for a starter?
The starter that went out (I think) is a CVR? high torque starter. Hasn't been on the car all that long. Have NEVER had an issue out of the starter before this.
Thanks
Take my word on this, the stock starter with the short bolt WILL BREAK and bust the mount off your block eventually, I've seen it a number of times. The stock one just isn't strong enough which is why gm quit using them.
Also posted In your other thread, stock pickup starter here 14.2:1 compression
It was 14X-150X$.
Started up the first key turn and sounds better than the other one.
Thanks for the input guys.
