Drag Racing Tech
Adjusting compression and rebound
Old Sep 19, 2013 | 05:58 PM
  #61
fly boy_1's Avatar
What would you say is ideal for the lca angle studderin?
Old Sep 19, 2013 | 06:12 PM
  #62
studderin's Avatar
you only only have 2 holes to use really, just not 5.8 and more then 1 lol.... you'll see, check out what it dose between them.
2-3* and work off that. I dont think I've ever had a 4* setup, so not sure.
You just took a endlink off the stock front swaybar, lol your shock and tire limited then whats the "best" angle would be for you. this is saying you made 100's of passes on the same parts, and you maximized everything else and know the car to .5 psi tires, 100 lunch rpms, 1 shock click, for the track at that pass and back it up. Its just unrealistic.
Just get it in the right direction and work for you and have fun.
Old Sep 22, 2013 | 08:04 PM
  #63
fly boy_1's Avatar
Hit 11's today. Went to the next hole up on the LCA brackets and kept an endlink unhooked on the front swaybar.
Old Sep 24, 2013 | 10:12 AM
  #64
Sales@Tick's Avatar
Very nice! There's a lot left in it with that MPH!
Old Sep 25, 2013 | 06:36 AM
  #65
studderin's Avatar
congrads
Old Sep 25, 2013 | 11:14 AM
  #66
fly boy_1's Avatar
Im hoping with the 2 step installed I may be able to get the launch cleaner and maybe get a bit more mph out of it. I wonder if I did a chrs1313 cai I could get the mph close to 120?
Old Sep 25, 2013 | 01:10 PM
  #67
BTLBABY's Avatar
Nice results!
What 2 step did you end up going with?
Old Sep 25, 2013 | 02:15 PM
  #68
fly boy_1's Avatar
I have a lnc2000, technically not a 2 step but same concept. I think Im gonna start my launch rpm around 5k and work from there.
Old Sep 25, 2013 | 02:33 PM
  #69
ssvert99's Avatar
LS1Tech Premium Sponsor
Great to see the results of the rearend, suspension parts, and shocks! The M6 trans launch tuning is a challenge for sure but they are fun to drive.
Old Sep 25, 2013 | 03:16 PM
  #70
fly boy_1's Avatar
Yes its a challenge alright! Takes a lot of practice and good parts, all the stuff I've gotten from MWC has been excellent. Went from 60's in the 2.2 down to 1.7, making progress haha. Im really curious to see how far I can go cam only with this car, i think the records are in the high 10's? I hope I can keep pushing through the 11's.
Old Sep 25, 2013 | 05:58 PM
  #71
studderin's Avatar
yes, good sealed front air source will be 2mph. deff a key mod for running fast
Old Sep 25, 2013 | 06:10 PM
  #72
fly boy_1's Avatar
How did you get your car trapping 127 cam only? Must be a really big cam to use the 4.30's in the rear, were you running a 28" tire? I'll have to go reread your weight reduction thread my car is probably a fair bit heavier than what yours is in your sig.
Old Oct 15, 2013 | 04:43 PM
  #73
ty_ty13's Avatar
7 Second Club
ideally at a racetrack you want a slick on a stick car. just a fyi.
Old Oct 17, 2013 | 01:30 PM
  #74
tyler ovel's Avatar
This one of the best threads that I have read since studderin's weight reduction page. Martin from tick, you sir are the **** for give out some really good info. Now I don't have Viking shocks but I do have qa1 DA rear shocks and am planning on trying some of the stuff mentioned in this thread to see if it can help me out. The only thing that is not going to help is that I still have stock front shocks.
Old Oct 17, 2013 | 02:13 PM
  #75
87silverbullet's Avatar
He has a Hoosier Drag on it.
Man you rarely post. Good seeing you back on here posting.
Old Oct 17, 2013 | 02:42 PM
  #76
fly boy_1's Avatar
The biggest thing is have someone video your launches. You need to be able to see what the entire car is doing to make these adjustments properly I found. A go pro on the rear quarter only does so much. I learned a lot from the advice in this thread, thanks again to everyone who chimed in!
Old Oct 17, 2013 | 06:29 PM
  #77
ssvert99's Avatar
^^^ And this is why you see me at the races with my customers at the starting line. The GoPro on a tripod is extremely helpful in making these cars work.
Old Oct 17, 2013 | 06:33 PM
  #78
ssvert99's Avatar
You will definitely want to get a good set of front shocks on that car. Weight transfer control is the start of the whole process.
Give me a call... I guarantee you the lowest prices and have a ton of experience tuning the suspension on these cars.
Old Oct 18, 2013 | 01:18 AM
  #79
tyler ovel's Avatar
Thanks ssvert99, right at the moment I don't have the funds for front adjustable shocks. Maybe around tax time but once I do have the extra cash I sure will be calling you!
Old Oct 18, 2013 | 09:15 AM
  #80
ssvert99's Avatar
We can help you for sure! Save as much as you can, as soon as you can... keep in mind a lot of the manufacturers will raise their prices before the end of the year. I can get you into a complete set of double adjustable front shocks for under 600.00
