Drag Racing Tech
Adjusting compression and rebound
Old Oct 19, 2013 | 04:10 AM
  #81
87silverbullet's Avatar
Originally Posted by ssvert99
We can help you for sure! Save as much as you can, as soon as you can... keep in mind a lot of the manufacturers will raise their prices before the end of the year. I can get you into a complete set of double adjustable front shocks for under 600.00
How much under $600? UMI just sent me an advertisement email and they have the front coilover kit for $549 and free shipping.
Old Oct 24, 2013 | 09:34 AM
  #82
tyler ovel's Avatar
Ok so I took the car to the track last night and tried out these new shock settings. I have qa1 24 way double adjustables, put the compression on 10 and started the rebound at 4 and kept the tire pressure around 18.5 psi and started my launching at a low rpm 4500. It bogged really bad that run so I upped the rpm until it spun. I then turned the rebound down until it started to hook.
I eventually got the rebound down to 1 and kept the compression at 10 and had the tire psi at 17. My best run of the night was an 11.29 @120 with a 1.64 sixty foot on a 6200 rpm launch spinning the tires a lil bit. These new settings feel pretty good, can't wait to try it out again and see where it goes.
Thanks again guys for writing up a good thread. Wish this was out years ago when I got these shocks
Old Oct 24, 2013 | 12:41 PM
  #83
fly boy_1's Avatar
What tires are you running tyler? Id like to get some better slicks when mine are done and get some actual drag slicks.
Old Oct 24, 2013 | 01:07 PM
  #84
tyler ovel's Avatar
Hoosier 28x10x16 full slick. Love these tires, they last twice as long as any mickey Thompson tires that I've bought .
Old Nov 6, 2013 | 04:32 PM
  #85
ty_ty13's Avatar
7 Second Club
main thing with a stick car is controlling the separation in the rear and making sure it doesnt bounce back up.
normally getting a stick car to work requires some specific shock valving when you are trying to go really fast.
Old Nov 8, 2013 | 03:36 PM
  #86
fly boy_1's Avatar
Interesting point on custom valving. Where would someone go to get a shock revalved? Ive seen madman does them for afco shocks, are there any others? Any input on when to revalve them?
Old Nov 9, 2013 | 11:50 PM
  #87
bigbrdf250's Avatar
Since were on this subject what would be a better starting point than what Viking recommends on there instructions for the front and the rear??
2000 Camaro 3 speed
4:11/spool
M/T drag slicks 28x10.5
Trans brake
2 step
Weight I'm not sure??
Old Nov 11, 2013 | 08:54 AM
  #88
ty_ty13's Avatar
7 Second Club
you can talk to madman, he's actually a very sharp guy. or talk to afco, penske, or jri or koni... they all have some sharp tech guys.
ideally you'd find the setting on the shock you have now that works the best. have them dyno it on that setting and have them make that certain setting your "center adjustment" and narrow the shock settings around it.
Old Sep 12, 2014 | 08:44 PM
  #89
mgood613's Avatar
I was searching around for viking d/a settings on a M6 and found this very informative. Thanks guys!
Old Jul 24, 2017 | 05:22 PM
  #90
Austin Power's Avatar
I need help with my 2000 camaro . Full suspension car
Can't get it to hook on the streets nothing . Viking DA shocks on rear , strange SA on front
