Anybody convert there factory rack to manual themselves?
So I want to use my factory rack opposed to a manual rack. I was told to do it right, oppose to looping lines, is to pull of the freeze-looking plugs off the rack am remove the o-rings off the shaft and reinstall the plugs or weld them shut and this is all that the converting places online does. Anybody do this vs just looping the lines? I don't like the look of looped lines and I like the gear ratio of a factory rack and with skinnies it doesn't bother me.
I got my factory rack modified to manual by Rack Doctor
http://shop.rackdoctor.net/CAMARO_c40.htm
I have not used it yet since by build is progressing slowly however other members might chime in on their results.
Mike
Mike
Mike
Mike
I've got a Rack Doctor's, and it turns nicely on jack stands.
But once it's on the ground, it's alittle hard to turn from a dead stop.
Once you get rolling it's not to bad. Nothing like ps.
But, I do have a small steering wheel and a spool.
Sometimes you just gotta tell yourself "it's a race car, not a dd". Personally I don't like the gear ratio in manual racks, I like the ratio in the factory rack. Take the good with the bad.
my buddy had one on his mustang when i drove it and it felt "loose". To make a lane change you needed to turn the wheel almost a half turn vs a 10th with our factory rack. Almost like driving a school bus with really bad tie rods, lol.
FWIW I have a madman manual rack and it works great from dead stop to driving. I have skinnies as well.
My other car has a converted manual rack and it works well. I feel them to be about the same.
IMO the work involved on one of these is very time consuming. YOU will need a large sized hydraulic jack and many adapters. A welder, snap ring pliers. A lathe or comparable.
Hammers and rubber mallet, A few other odds and ends.
THe main thing is a know how of what to do with common sense.
So 225 for a complete unit with new inner tie rod ends and lifetime warranty is worth it IMO.
