Drag Racing Tech
Help removing some wiring
Old Nov 1, 2013 | 11:21 PM
99Z28camaro's Avatar
Default Help removing some wiring
Did a few searches and didn't find much. I am stripping my car car down now for mini tubs and cage and was going to strip some of the unnecessary wires out. Was wondering what all I can remove? and can anyone tell me how to fully remove the bcm from my car and it still start? What all do I have to rewire to make the car still run without the bcm? The car is a 99 z28. Thank you in advance for any help.
Old Nov 2, 2013 | 05:11 AM
Orange99Z's Avatar
https://ls1tech.com/forums/showthrea...0#post17792850
Disable vats in pcm, ground yel/blk wire.
Old Nov 2, 2013 | 01:00 PM
Thanks man....is the bcm the small box that was behind the radio or the bigger box that was behind the passenger side kick panel?
Old Nov 2, 2013 | 01:07 PM
RENE'S RAGE's Avatar
Pass kick panel.
Old Nov 2, 2013 | 02:21 PM
Ok I have 2 yellow wires with a black stripe. Do I just ground both of them?
Old Nov 2, 2013 | 04:51 PM
No, just the yellow/black on C11 on your BCM.
Old Nov 2, 2013 | 05:33 PM
5.3LJimmy's Avatar
Every wire that runs along the floor near the passengers door jamb can come out. These are all for the stereo and power antenna.
Old Nov 3, 2013 | 09:56 AM
Firebirdmuscle's Avatar
If you delete the shock sensor on the pass rear tub will the remote key still work or does anyone know?
Old Nov 3, 2013 | 02:19 PM
95killerz's Avatar
Yes I removed my sensor and fob still works fine
Old Nov 4, 2013 | 08:18 AM
Okay thanks. Will try it out
