Building of The Mistress
LME LS2 402, everything callies and forged
9.5-1 compression
236/248 640/640 on a 114+4lsa
ARP main studs and 12 point head studs
Billet steel 24x reluctor ring
Trick Flow 235cc CNC heads
JP performance LS2 double roller timing chain w/ torrington bearing
LS7 lifters, LS2 trays
Manley 7.550" x 5/16" x .083" wall one piece chromoly
push rods
Yellow Terra Ultra Lite aluminum shaft roller rockers
GM MLS LS9/ZR1 Head Gaskets
Melling 10295 high pressure, coated oil pump/ ported
Moroso sheetmetal aluminum oil pan w/ billet rail, full
length windage tray & custom pick up tube
And of course all the other stuff like seals, bolts, gaskets to go with it
