Drag Racing Tech
Building of The Mistress
Old Nov 23, 2014 | 11:20 AM
  #121
silverls1z28ofdeath's Avatar
Whose cage is that in your car? Looks like a mwc?
Old Nov 23, 2014 | 06:56 PM
  #122
chewy99ws6's Avatar
The 6pt part is from wolfe, the rest of it was built by one of my buddies here to a full 10pt.
Old Nov 25, 2014 | 07:26 PM
  #123
chewy99ws6's Avatar
Got a bit more done today, built trans cooler lines, installed SYA bars, FMIC, wired up trans cooler fan, ran all wires from inside to engine, ran wire from alt to fuse block, relocated alt, got a new black alt so this one is just for mock up. Installed procharger belt, pipes from procharger to FMIC with red BOV, and plug wires with DEI heat sleeve.
Old Nov 29, 2014 | 08:37 PM
  #124
chewy99ws6's Avatar
First start-up o the car in over a year.
Old Dec 2, 2014 | 01:44 AM
  #125
JR 427's Avatar
Just read the whole thread. Awesome set up!
OP, do you mind taking better shots of the NO vapor kit you have on there? If like to see how it's all routed/fittings if you don't mind. I need to buy one but want would rather see installed pics before spending 250 bucks on one!
Thanks!
Old Dec 2, 2014 | 07:58 AM
  #126
RENE'S RAGE's Avatar
Cool on the start up!
I know you're excited.
Old Dec 3, 2014 | 10:55 PM
  #127
chewy99ws6's Avatar
Yes I am stoked I am getting so close. I started bleeding the brakes today and radiator. Built a switch panel to go were the radio used to be. Just have small things left to do now.
Old Dec 6, 2014 | 09:13 PM
  #128
chewy99ws6's Avatar
Got a few more things done this week, trimmed dash pad, bled radiator and brakes, installed meth kit, windshield going in Tues and hoping to get driveshaft this week then can finally drive car. Took a quick pic of the bird outlined in pink light, 1 of 3 places there is pink on the car for the wifey.
Old Dec 14, 2014 | 08:41 AM
  #129
chewy99ws6's Avatar
Had a small photoshoot yesterday.
1. I know the car rides a bit high but with the big and lil's it sits a lot better.
2. A lot of people have been fussing about the bird blocking airflow, I only leave bird in there for car shows, when at the track I remove the bird for better flow into intercooler.
Old Dec 14, 2014 | 12:01 PM
  #130
98Camarod's Avatar
Good looking ride!
You must be short, those seats are way up!
Old Dec 14, 2014 | 03:09 PM
  #131
chewy99ws6's Avatar
Originally Posted by 98Camarod
Good looking ride!
Thanks, I am actually 6', the way I set them up I am very comfortable.
Old Dec 22, 2014 | 09:06 PM
  #132
chewy99ws6's Avatar
Got the exhaust done on the car today, 3 1/2 inch all the way back. V-bands on the front for easy removal if needed to an H-pipe then to Borla XR-1 mufflers dumped at axle
Old Dec 22, 2014 | 09:49 PM
  #133
IronBlocked's Avatar
She's coming along nicely! Thank you for your service.
Old Dec 23, 2014 | 01:11 PM
  #134
chewy99ws6's Avatar
She sounds so much better with exhaust on her, she will be getting a full tune next week at Vengeance Racing
Old Mar 2, 2015 | 12:34 AM
  #135
chewy99ws6's Avatar
First dyno pull, 93 no meth, not a lot of timing, ended up maxing out my 80lb injectors and dual 255 pumps. Swapped out to new dual 450's and 110lb injectors, will be back on the rollers mid-march and this time actually be able to use the meth, we hit 13lbs so far and should hit right around 20lbs when done.
How she sounds with the tune
Have done a few more small mods so far
Strange drag brakes for the rear
Moser gun-drilled 35 spline axles and lightweight spool
Ordered parachute and mount
Made a small decal for the front air dam for when my wheels are up
Had to rep for my tuner and also put on his decal
Old Mar 2, 2015 | 01:23 PM
  #136
98Camarod's Avatar
Nice work man! Glad you got it going! What type of numbers did you put down?
Old Mar 2, 2015 | 03:43 PM
  #137
chewy99ws6's Avatar
93 and no meth, very first pull made 663, he says his dyno reads insanely low and on another one it should be around 850, so we are hoping when I go back next week to be around 1k when said and done
Old Mar 18, 2015 | 10:36 AM
  #138
chewy99ws6's Avatar
Finally got back on the dyno with the new pumps and injectors. This time we had belt slip at 14-15lbs but still pulled off just under 900hp. The belt slip was due to me having a belt that was .5 inches too long, so I ordered a shorter gates green belt this time and that will fix the problem. I should then see 18-20lbs and closer to 1k hp. First track test will be April 3rd. Not the best videos but better than nothing.
Old Mar 18, 2015 | 09:53 PM
  #139
Uneverknow's Avatar
Awsome build! Motivates me to get my drag build moving faster. Thanks for your service!
Old Mar 19, 2015 | 12:10 AM
  #140
chewy99ws6's Avatar
Thanks
