Drag Racing Tech
7.3 to 7.0 is it do able?
Old Apr 29, 2014 | 06:51 PM
stherngent's Avatar
Default 7.3 to 7.0 is it do able?
My car is a 5.7 with street heat 2 cam, ported 241's , Ls6 intake ,ported tb, UP, 1 3/4 pacesetter headers, true duels, 4000 stall, 3.73 gears. I'm running 1.60 60ft @ 7.38 1/8mile. I want to get to 7.0 N/A. What to I need to do?
Old Apr 29, 2014 | 07:19 PM
ragtopz28's Avatar
That's a pretty good time! What is mph?
Suspension upgrades? Weight reduction?
Old Apr 29, 2014 | 07:28 PM
madmike9396's Avatar
how much gas was in the car when you ran 7.3 ?
pull back seats and spare tire and jack if you haven't already
Old Apr 29, 2014 | 08:00 PM
stherngent's Avatar
Mph 92.76, qa1s front and back trying to learn how to set them up. LCA' s, adj. torque arm. 15 3.5 fronts/ 10 back. Rear seat taken out, a.I.r and get deleted, front support removed, driver seat removed and kirky installed. Spare tire and Jack removed, front sway bar removed.
Old Apr 29, 2014 | 08:43 PM
93camaro_zzz's Avatar
You want to go 7.0 N/A? I noticed you didn't mention a budget at all. So... on that note, go ahead and grab a FAST 92/92 combo and some Trick Flow 215's, or grab some 243's to send off for a CNC job by WCCH/TEA/AiResearch. That should give you a pretty nice bump in hp, and should be able to get you to that 7.0 mark.
Old Apr 30, 2014 | 10:32 AM
stherngent's Avatar
From what Ive read looks like I need to change to 1 7/8 headers first then to better heads then better intake/tb...
Old Apr 30, 2014 | 11:58 AM
RENE'S RAGE's Avatar
Nothing wrong the size if your headers. With the power your making.
Get you some heads. TEA TFS 215's. Use to be top of the line.
Old Apr 30, 2014 | 12:05 PM
You are correct in the fact that 1 7/8" headers will flow more, and will make more power on your combo. But looking at your combo and a good order to buy parts in... you stock size throttle body, and a stock unported head are what is killing your power alot more than 0.125" on your primaries. Search around for how much power people have made on 1 3/4" pacesetter headers. You will be amazed.
But I guess what I didn't explain before, is you kind of have to analyze your own ET to see what it is missing. It looks like as of right now, you are not going to be able to get that much more out of your sixty foot, and even though 92.5mph is not BAD for a 7.3 run, if you could get the car to trap 96ish, I believe that is going to be your ticket to 7.0's.
Old Apr 30, 2014 | 12:29 PM
Zmg00camaross's Avatar
I would shot for 6.9x or faster to hold some numbers if need be. If you get that 60ft down it be there.
Old Apr 30, 2014 | 02:57 PM
A guy has a seat of TFS 215's with HS rocker arms for 2 grand, in the for sale section.
dennisgreener is his screen name.
There you go!
Old Apr 30, 2014 | 04:25 PM
stherngent's Avatar
Thanks guys
Old Apr 30, 2014 | 07:18 PM
carolinaSS's Avatar
Who did the porting on the heads?
Old May 1, 2014 | 09:52 PM
stherngent's Avatar
A local shop
Old May 1, 2014 | 10:12 PM
handyandy496's Avatar
Are you running bias ply slicks? Are they newish?
Old May 3, 2014 | 08:55 PM
stherngent's Avatar
I am running bias ply slicks the wear holes are almost gone maybe close to an 1\8 " left.
Old May 3, 2014 | 08:57 PM
stherngent's Avatar
What about different gears 4.11 ?
Old May 3, 2014 | 09:19 PM
senicalj4579's Avatar
Mine did 7.007 3450-3500 raceweight but the da was -1000
You have a bigger stall than me. A ssra will help a lot. Fast 92. Weight reduction...
