Weight reduction list!!!
-- EDIT --
Just got an e-mail from Flex-A-Lite. The heater weighs 7 lbs. The plenum vent box weighs 2. Just an FYI.
bmr chro/moly panhard
bmr chro/moly torq arm
bmr chro/moly lower control arms
convertible sub frame connectors
qa1/hal shocks and springs
meziere elec water pump
does seem like any of these are weight reduction items, (haven't installed them yet)...am i ahead or behind?
Edit, with the TCI stall and ASP pulleys, you have balanced out the subframes, I would say. So, probably 40-50 pounds lighter than bone stock.
I took my Summit racing coolant overflow tank out of my 72 chevelle and put it in the bird.
I ditched the stock coolant overflow tank and lost 5 pounds.
Most due to less coolant but also due to removing the huge black container and replacing it with a tiny coolant over flow tank
I'm at 2950 now in search of getting lighter!!
Stock 2000 SS 17X9 rim with 275/40/17 Tire = 54lbs X 4 = 216lbs. Centerline Convo Pro 15X4 rim with Mickey Thompson ET Front 26X4.5X15 tire = 24lbs X2 = 48lbs. Centerline Convo Pro 15X7.5 with Mickey Thompson 26X10.5X15 w/ Tube = 39lbs X 2 = 78lbs.
That is a total weight saving of 90lbs just in rims and tires. For those that might use different tires (I will probably go to 28" tall for the back myself soon) the front rims are 12lbs each and the rear rims are 14lbs each. Front tires are 12lbs each and rear tires with tubes are 25lbs each.
I could shave a second off my car by doing all the weight reduction mods and having a 120 lb guy drive it for me.
I guess I will just add nitrous and not tear my car apart!!
You guys are way more hardcore than me!
SDB
Brad
Any info would be nice.
I ditched the stock coolant overflow tank and lost 5 pounds......
. http://f2.pg.photos.yahoo.com/ph/ara...m=IM009091.jpg
