Drag Racing Tech
Weight reduction list!!!
Old Aug 2, 2003 | 07:19 AM
  #161
redz_02's Avatar
Default Re: Weight reduction list!!!
colenel, does adding a chromoly torque arm reduce weight?
Old Aug 2, 2003 | 09:30 PM
  #162
Colonel's Avatar
Compared to stock? I doubt it.
Old Aug 2, 2003 | 10:39 PM
  #163
whitt1's Avatar
Strip that baby down to the unibody dig a pit in the back yard and acid dip it like they did in the sixties.Pensky's TransAm Z28 camero had a vynal roof to cover the holes from where they left it in the pit to long,but that baby was light.
Old Aug 6, 2003 | 08:51 PM
  #164
next's Avatar
Does anyone know if there is a weight difference between Prostars and Draglites?
Old Aug 7, 2003 | 12:25 AM
  #165
quickWS6's Avatar
I don't think there is any noticeable difference between Pro-Stars and Draglites.
Old Aug 8, 2003 | 07:45 AM
  #166
smokinHawk's Avatar
I took off the Evac boxes on the 99+ plastic tanks and it weighed 4.5lbs
Old Aug 17, 2003 | 10:51 PM
  #167
HPZ95MARO's Avatar
Does anyone have any idea what the side impact beams weigh??? i took mine out today so if noone knows i will weigh them
Old Aug 18, 2003 | 02:02 PM
  #168
Larry's Avatar
See my post and pic above dated 7/27/03
Old Aug 19, 2003 | 09:13 AM
  #169
WS6snake-eater's Avatar
How much of a difference is 100 lbs worth in the `1/4.
Old Aug 19, 2003 | 09:15 AM
  #170
next's Avatar
Here's a what most use
100lbs = 1/10th
Old Aug 27, 2003 | 03:35 PM
  #171
quickWS6's Avatar
Come on everyone, it's time for some new ideas!
Old Sep 1, 2003 | 10:32 AM
  #172
T-maxx's Avatar
I drilled 1/2 inch holes all over my car, fenders, hood, rims ect. Saved 11 #. My plate reads... SWSCHZ.
Old Sep 5, 2003 | 12:43 PM
  #173
Excal's Avatar
ummm what about all the vfn stuff, doesnt' seem to be used as much as it shoudl.
Old Sep 7, 2003 | 11:41 AM
  #174
stealth's Avatar
If I took my car to MTI, could they put my car on a Jenny Craig diet and remove a couple hundred more pounds? It weighs 3400 w/o me in it, but it has a CI block, T400 and big blower.
Old Sep 22, 2003 | 09:27 PM
  #175
Magnus's Avatar
LS1TECH Sponsor
Here is some stuff I weighed up on a VERY accurate scale today:
HVAC/Blower Motor: 20.5 lbs
Dash: 11 lbs
Sound Deadening and padding: 12 lbs
Drivers side carpet: 8 lbs
Passanger Side carpet: 7.5 lbs
Passanger Air Bag: 14.5 lbs
Misc duct work/tubing: 6.5 lbs
Cross bar & brackets: 7.0 lbs
Note: Carpet is cut about 5 inches behind rear set bolts.
Old Oct 2, 2003 | 08:48 AM
  #176
TTtop's Avatar
I weighed my Meziere EWP and the stock WP today on our digital shipping scale at work, here are the numbers:
Meziere - 15 lbs. 3 oz.
Stock - 12 lbs. 12 oz.
So 2lbs. 7 oz. heavier! The 8-12 rwhp gain is nice though!
Old Oct 6, 2003 | 11:12 AM
  #177
ou812/z28's Avatar
I have the passenger side airbag on my list but I've been avoiding it by removing other things. I also bought some light weight seats. I've been trying to find out if there is an easy way to remove the airbag also.
i removed my passinger air bag in my 94 and it wieghed 17lbs.
Old Oct 6, 2003 | 11:15 AM
  #178
ou812/z28's Avatar
Anyone weigh the power window equipment vs. manual? Or maybe I missed that.
i went from power to manual on my 94 and cut off 10lbs per door.
Old Oct 6, 2003 | 11:27 AM
  #179
quickWS6's Avatar
Could you give some details on what is involved with this swap, how hard it is, and what is needed?
Old Oct 6, 2003 | 01:57 PM
  #180
ou812/z28's Avatar
i purchased another 94 with roll up windows. removed all window regulators form both cars and swaped. pulled the power window fuse and the door panals are already set up for roll up windows, all u have to do is cut the holes and adjust the windows. it is no hard. last u pull the harness as for back as u can in the vehicle and cut the harness then rap with black tape. looks as if it came that way from the factory.
