Need to talk shocks/springs
-welded in subrame connectors
-lower control arms w/ relo brackets
-tunnel mount torque arm
-panhard bar
-8 point chromoly cage
-MWC weld in drag bar
-s60 rearend
Currently I've got the 2step hitting at about 3000rpm and building 12psi off the brake. The tires are MT pro radial's with about 17psi in them. Car is all of 3800lbs with me in it. Best 60' i've cut is a 1.47 and if I push the 2step a little higher I spin terribly. I'd like to leave harder and think my cheap KYB ABX shocks on stock springs are holding me back. What do you guys think?
So i'm not looking to break the bank but at the same time i don't want to get some cheap crap thats not going to help me out. What do you guys recommend?
Here are some pics and a vid.
The best performing setup for the money is the Viking Performance double adjustable shocks which include the front and rear shocks, springs, spanner wrench, and bearings to make the ride height easier to adjust. If you are looking for something a little cheaper you can get away with doing the Strange single adjustable shocks all the way around which will be a couple hundred dollars cheaper and will include the front and rear shocks, Hyperco coil-over springs, and bearings to make the ride height easier to adjust.
Before I would be able to recommend a spring rate for your vehicle I would need to know what weight has been taken off and/or added to the front of the vehicle. I would also need to know what kind of ride height you were looking for. I would definitely be more than happy to help you out if you could get me some more info on the car.
Kyle
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Kyle my stock ride height is a-ok for me on my stock springs if that gives you an idea. Just so happens when I got my car weighed when I got the cage put in. Unfortunately this is without me in the car. So this doesn't include driver weight of 200lbs and I also removed the stock front sway bar.
Since you are happy with the stock ride height and haven't done really much weight reduction on the front of the car I would run somewhere in the 325lb-350lb spring rate and you should be happy with it. Anything lighter and you would probably have a hard time getting back to that factory ride height due to the weight on the front of the car.
I am still here, just tough to be on here a bunch with phones ringing like crazy here at the shop.
Glenn ***
Sales Tech
813.986.9302
Viking Performance has their double adjustable shocks which most people use but they have worked with a couple other companies to provide a true coil-over for the back if that is what you are really looking for. It just really depends on what you are looking for as far as ride height goes. I know I have set up a couple of Viking Performance combinations with our BMR rear lowering springs for guys that wanted a lowered ride height and they were very happy with
Glenn ***
Sales Tech
813.986.9302
Yep, this is what I would do. Like I said this setup will compensate for the extra weight on the front of the vehicle and allow you to stick right around the factory ride height without any issues. Plus sticking with the Viking rear DA shocks will save you some money over the true coil-overs.
Glenn ***
Sales Tech
813.986.9302
The biggest benefits of coil-over rear are 1) adjustable ride height 2) slightly lighter spring, 3) great selection of spring rates to suit your needs for what you do with the car.
There are no magic numbers with performance in coil-over vs standard location spring, but I can tell you the quickest and fastest f-body cars on stock style suspension are all on coil-over rear shocks(we set them up).
We can help recommend the correct spring sizes and rates for what your needs are without issues... we have a lot of experience with this setup and have helped 100s of customer with springs.
Give us a call... MWC sells more racing style shocks for f-body street cars and racers tan anyone and we have the expert tech help and experience to back it all up. Not to mention the guaranteed lowest prices!
Glenn ***
Sales Tech
813.986.9302
