What crossmember/torque arm do you have?
Just curious what everyone is using?
I have a BMR crossmember with the torque arm relocation for a th350 and stock torque arm. I'm looking at adjustable torque arms but wondering if I should have went with a different crossmember.
I see some crossmembers (spohn) where the torque arm bolts rather then using a bracket to hold the front of the torque arm.
Are the BMR crossmembers more of a street application and Spohn is more of a drag race application?
I have the TA013 by BMR which is tunnel mount (Seems to be very good quality ). Which means that you wouldnt haf to touch your trans crossmember(if thats what you were referring to as "crossmember"). I think Spohn and BMR distinguishes between their street application and there strip application.
I've noticed some crossmembers have that brace to hold the torque arm and some a bolt goes through the torque arm and through the crossmember. Or am I confused/
Just thought the brace looks cheap or for a street car application.
Both ta and crossmember?
I think I have the same crossmember but with stock torque arm.
Hi-ho the true dual crossmember that MWC sells is a great crossmember that will leave you a lot of room for a dual exhaust. I had a TSP true dual setup and a custom true dual setup and that crossmember left me with the most room.
I am on my second MWC short torque arm with my new car but have the front fender exit crossmember. I know I have pics of my newest one. Let me see if I can find pics of the old true dual setup.
And I could of swore the crossmembers were on the website. But I could be wrong. Let me see if I can find some pics
Here it is on my car, tough to see the crossmember with exhaust in the way. I think the pick up point is pretty close to everyother short torque arm. The arm doesn't seem to be up any higher than the UMI arm I had on it.
