Drag Racing Tech
Who's going fast on 26" tires?
Old 09-22-2015, 09:46 PM
JWStevens's Avatar
Default Who's going fast on 26" tires?
I'm thinking about going to a 26" tire and I was seeing who was running them with good results. I think my 28's are killing my gear on the starting line. Any Pics, timeslips, or any info on 26" tires on a 4th gen would be greatly appretiated!
Old 09-22-2015, 11:43 PM
JWStevens's Avatar
Well damn, Tech has died I guess? I can't even get some smart *** to comment here lately. I'm not trying to go super fast. 6.50's maybe?
Old 09-23-2015, 07:10 AM
sillysspeed's Avatar
I'm running 26" right now with 4k stall and 4.10 gears. Car is topping out at 123mph with the limiter set at 7k rpm. I just picked up a pair of 28" cause it's hitting limiter at the top of the 1/4 mile. Im hoping the 28" don't kill my et. You shouldn't have any problem tho if your running 1/8 mile or a little less gear
Old 09-23-2015, 07:43 AM
vetteboy2k's Avatar
We have always run 26" tires that measure less based on rim size etc..
Both with automatic and stick vettes even up to 700whp. Most quality tires are good for low 1.4x so if you can get them to hook and that's all you need you're better off with a 26.
Old 09-23-2015, 09:02 AM
JWStevens's Avatar
Yeah, we run 1/8 mile 99% of the time. Its my daily so I don't want to go any lower the a 3.70 gear. I just started taking it back to the track and I ran a 7.40 with some light wheels spin and the a few days later I went to a track that was dead hooking and it was running low 7.50's. The first track's 60' bulb was broken so I couldn't compare the two but I've got a low horspower motor so I'm sure it lugged it when it dead hooked.
Old 09-23-2015, 10:25 AM
6SSPEED's Avatar
running 7.1's here on a 26" hoosier. 383 stroker w/ 3:73 gear 12 bolt. Full weight (3600)
Old 09-23-2015, 12:10 PM
JWStevens's Avatar
Hopefully, I'll be in the 6's on this little bit of nitrous. Next year I'm gonna upgrade so I'm hoping I can make the 26's work.
Old 09-23-2015, 03:07 PM
Mystery Bird's Avatar
I run 6.9x in the 1/8 with Hoosier 26 DR and a 3.90 gear. Best 60 is 1.46.
Old 09-23-2015, 06:31 PM
RobsZ28's Avatar
I'm still working some things out on my car, but so far I've been 6.801@ at 98 spinning on a 235/60/15 M/t radial. Once I get power management and suspension figured out again I should be back down to 6.2-6.3 on the 26" tire. Outlaw 8.5 guys are running 4.65-5.10 on 26x8.5 tires, you should have no problem running 6.50.
Old 09-23-2015, 10:26 PM
01ssreda4's Avatar
Run 7.0s all day on a 26 (275/40/17) et street radials
Old 09-23-2015, 10:47 PM
JWStevens's Avatar
I also would like to see a good profile shot of some 26's on a 4th gen. Anybody got any?
Old 09-24-2015, 06:48 AM
The Hoosier DR are actually slightly smaller than 26". I think it's 25 3/4". You can see a difference if you hold them side by side with a MT 26" but in my experience they work better.
Old 09-24-2015, 08:17 AM
willizm's Avatar
I ran mid 10's at 134mph on a 26" MT ET Street with a 1.4 60'. I switched to a 28" since i'm gear limited to 3.54 so I need every bit I can to cross the traps without bouncing on the limiter.
Old 09-24-2015, 09:30 AM
ALZ28's Avatar
Hoosiers 26 x 10 x 15
I run 15PSI
Old 09-24-2015, 09:58 AM
Heyfred's Avatar
What shocks are you using?
Old 09-24-2015, 10:18 AM
ALZ28's Avatar
QA1 drag fronts & QA1 coilovers on rear, single adjustable
Old 09-24-2015, 10:35 AM
I run 15PSI
Those must be the bias ply QTP's? They look bigger than my 26" DR.
Old 09-24-2015, 10:36 AM
JWStevens's Avatar
I just got these this week.
Old 09-24-2015, 10:54 AM
ALZ28's Avatar
Slicks, at the end of their life.
Thinking of going back to DR's
probably the MT Bracket ones
Just to keep it more stable at the top end.
Old 10-12-2015, 09:12 PM
NewOrleansLT1's Avatar
I'm cutting 1.50 60ft with 26" Hoosier radials 3:73 gears out back 4,000 stall
Quick Reply: Who's going fast on 26" tires?
