should I do it?
Can you? Yes. Would it be that big a risk/difficult? Probably not, depending on how you do it. Should you? No. Should you: install a forged rotating assembly and some high flow heads along with a big, properly matched cam? Why not?
400-420 hp is easily doable with a nice mid 230's cam and some 243 heads with at least a valve job and a little milling to bump up compression and some long tube headers/exhaust..
You also need supporting mods that go with any head/cam swap
To make 450-500 will almost cost triple the price of the above, meaning aftermarket heads or CNC ported 243 heads, fast 102 intake, 1 7/8 headers, true dual exhaust, max effort cam.. List goes on
Huge diff in price to go from 400 hp to 450-500 hp on the ls1 engine.
