What would cause a car to do this...
Car 98 Formula, BMR TRAK PAK -2.5 deg on the torque arm, Lakewood LCA's, Airbag in the right rear spring, stock springs and shocks all the way around, ET Streets with 17psi in each, stock rear sway bar no sway bar up front...
Now to the problem. The car has never done this at ALL. The car would hook off the line but then would sway back and forth real bad causing me to lift. Figured it was just the track. I let the car cool down for an hour checked the tire pressure made sure everything was even(17psi rear 50psi front) The went back up and chose the other lane. This time the car hooked harder(better burnout
) and then started to go side to side even harder and I had to lift before the 1/8 then tried to get back into it and the car continued to do it even worse
We check all the suspension points to make sure all was fine and no binding was happening. I went to check the airbag's pressure but screwed that up by not having the pressure gauge on there square and let a ton of air out, pressure reading after my screw up was 5psi so it could have been low. Would a low air bag cause this? I normally run the airbag at 17-18psi and hook 1.60fts... last night I was hitting 1.79-1.70's
Any help would be great.
J
Thanks Tho
Thanks Tho
Back to teh topic.
Have you checked your panhard rod and control arms for straightness?
I run the Metrics up front too, but the car has never done the shimmy right off the line. With 17psi in the rears she is pretty stable on the topend, but I couldn't even get it to the 1/8 last friday without it trying to swap ends. So I only made two passes and called it a night.
Check list, pull the LCA's and panhard bar to see if they are tweeked. Any other suggs? How about the low airbag in the right rear, will that cause wacky launches?
Thanks all, keep it coming.... I need to run a 6.90-6.99 in the 1/8
I'm hoping the Spohn sway bar fixes that, along with my sideways launches.
