Drag Racing Tech
Whos anti roll bar should I get?
Old 10-19-2016, 09:21 AM
k_garretson23's Avatar
Default Whos anti roll bar should I get?
Who has the best anti roll bar, mwc, umi, or bmr. What are you running, how does it perform?
Old 10-19-2016, 10:21 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Is it a street car or dedicated track car? Our bar has been proven to last for street duty as it has no concentrated stress points like a lever arm style bar, and has also been used into the low 1.1 60' range without any flex. It also retains the stock gas tank and is 100% bolt on
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 10-19-2016, 11:06 AM
Its like 85% track 15% street. Im about pushing the limits on streetable.
Old 10-19-2016, 11:24 AM
BlackSS2001's Avatar
UMI and I love it! I am mostly on the street with mine and it's holding up good.
Old 10-19-2016, 11:28 AM
MidwestChassis's Avatar
We offer one of the lightest and strongest anti roll bars on the market with zero clearance issues with gas tanks and rear shocks like some of our competitors do. And we offer a weld on and bolt on chassis bracket to make installation a breeze.
Old 10-19-2016, 03:10 PM
RENE'S RAGE's Avatar
Mwc!!
Old 10-19-2016, 05:27 PM
nj02z's Avatar
BMR, no issues at all.
Old 10-19-2016, 05:51 PM
Zmg00camaross's Avatar
MWC here! Light and strong.
Old 10-19-2016, 10:14 PM
01ssreda4's Avatar
Mwc, very lightweight.
Old 10-20-2016, 12:01 AM
BOLO's Avatar
I just installed a MWC bolt on anti roll bar. Easy install and very light.
Old 10-20-2016, 10:58 AM
WVhuggerSS's Avatar
I had a umi and switched to the mwc to save weight both good products though.
Old 10-20-2016, 11:22 AM
codyvette's Avatar
BMR on my drag car, works fine. In fact, my entire suspension is BMR. I can hook on dirt and my wheelies are arrow straight. My car has a stock motor though so it will hook on dirt.
Old 10-23-2016, 01:35 PM
z28a4's Avatar
MWC here. I was so surprised at how light it was. I'm very happy with it. Bought it last year on their black Friday sale. I think it was only $340 but I can't remember. Just something to keep in mind since that time of year is right around the corner.
Rob
Old 10-23-2016, 03:17 PM
Nitroused383's Avatar
Just make sure your ARB isn't one like mine that goes right under your rear end. My drain plug is blocked and I will never be able to access it again
Old 10-23-2016, 07:08 PM
jhshnh's Avatar
I run the BMR bar on my S60 and love it. Easy installation and 0 flex. I drive a lot on the street and it rides great to me. I'd have no problem daily driving it.
Old 10-27-2016, 09:25 AM
TXCatfish's Avatar
Black friday only a month away. Wonder if mwc will have it on sale again.
Old 10-27-2016, 10:31 AM
MidwestChassis2's Avatar
We should have sales on certain common items.
One thing to keep in mind is ours is actually that, an anti roll bar not a sway bar. It allows zero side to side movement of the bar which is important to keep it from hitting your shocks plus performance and we use a oilite bushing instead of poly or rubber which is also important for performance as the oilite bushing is not only self lubricating it does not allow the bar to push through the bushing.
We offer our ARB for any type of housing and can be fully bolted in place or weld-in. We do prefer the weld-in over bolt in chassis brackets but both perform very well. Not to mention our ARB does not block drain plugs, it sits behind the housing not under it.
If your housing does not have welded on sway bar brackets we have those available, which is very important as exhaust clamps can twist on the housing under force.
Available for purchase here and are free shipping.
Old 10-27-2016, 10:40 AM
93camaro_zzz's Avatar
I have the Wolfe weld on drag ARB. I love it. I am sure MWC's is just as good though. But if it is more than 50% track use, I personally would put a drag bar on the rear. Here is a pic of it and the Link. I never have had clearance issues with it, but then again I don't street drive that much, and I am on a 28" rear tire.
http://www.wolferacecraft.com/detail.aspx?ID=217
Old 10-31-2016, 05:31 PM
Race your car!
JL ws-6's Avatar
I am a fan of the Wolfe bar for a stockish 4th gen car suspension wise... if you are building a race car with no stock tank I would look into one of the pro style bars that's made with what's essentially an axle shaft. Make sure there's grease fittings in whatever you buy and its heim joint mounted to the body so what movement it does have is on a heim style joint, no bind just the bar doing its job.
Old 11-01-2016, 04:39 PM
Ill probably make that purchase as soon as I get the bugs worked out of the tune
Quick Reply: Whos anti roll bar should I get?
