Best ET w/G5 AND Ported Heads vs Stck Heads
Just checking around to see who has what results w/ the G5. I know some guys got runs w/stock heads also so maybe we can get both posted here. I am curious to see the difference that's out there. I ran 11.85 at 115 with my car and a bad tranny. What did you all run? Please list major mods and times. Mine is below.
JPR LS6 S2 Heads, LG G5 112 cam,Promatic Built A4,Vig 3600, Whisper Lid,FTRA,ARE Oil pump, Katech timing chain, ported throttle body, K&N,BMR STB, Stock MAF, Ed Wright Custom Tuning, LS6 Intake,DD SFC & LCA'S, RT Adj Torque Arm, BMR DS Loop, SLP Long Tube Headers, Corsa, Hotchkiss Adj. PHR,3:73's, ASP Underdrive pulley, Wolfe 6 pt weld in Chromoly cage, KVR Crossdrilled Silver Rotors and Pads, Hurst linelock, ET Streets ,custom sound system w/JL sub.
400rwhp unlocked
395 rwtq
11.92 114 wife ran 11.85 @115
<small>[ May 06, 2002, 08:49 AM: Message edited by: Bear ]</small>
400rwhp unlocked
395 rwtq
good times for a bad tranny <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
What was the problem with your tranny? Was it slipping?
Cheers,
Chris
Cheers,
Chris
12.4 @ 112(1.9 60ft) G5 cam with stock heads on ET Streets. Still needs tuning. 4 deg of knock and shifted at 6k. Should have better times within a couple of weeks.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris ARE 360:
<strong>good times for a bad tranny <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Cheers,
Chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Don't know yet. Joe Prince was supposed to have it out on Thurs or Fri of last week and then have his guy look at it. I will be doing something to correct the problem as soon as I hear from Joe.
Cheers,
Ran this a couple of weeks ago in 90+ weather(time in sig). My tranny is also slipping. Kept banging the limiter on the 2-3 shift. Going to have the clutch packs replaced. I'm also going to have LG change my shift points to see if I can get more out of this cam. We are going to use LS1-
EDIT and their wideband dyno tuning this time. Maybe we can finally get this cam tuned properly. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
DMoney we have very similiar setups except for the MAcs. I am also in the process of setting up some MAcs for me too. I thought that with the size of the cam and the parts we had we would get better numbers. I ran a best of 12.31 at 111 on Nittos before H&C. Now with them I ran 11.9@114. Seems like something is not right. Maybe this cam is the answer for peeps who want to keep stock heads, but the numbers are low for us S2 guys. <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> Keep the info coming. Where is Crowley?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JS:
<strong>Put the TR Cam in her Bear.
It works.....
JS
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Soon my pretties, soon <img border="0" alt="[pimp]" title="" src="graemlins/gr_pimp.gif" />
It works.....
JS
Lot's of cam work. The question is how much vacuum do they pull at idle. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
H/C, ASAP Pulley, FLP Headers, SLP Catback with no cats, FRA, GMAF, LID, cut-out, 3:73 gears, 3200 vig., carbon fiber driveshaft, skinnies, etc. Car dyno once 387 and 391. The best time ran was 11.72 with a 1.63 @117.14 MPH. Of course this is the G5 CAM. Although this may not be a specular time, this time was ran on 17 Nitto's with skinnies on front. This setup has ran several 11.8's with all big 17 inch tires on and cutout not open and hardly no weight reduction. My future plans are to run convo pro's with MT slicks to try improve my 60'time for a better ET. I sincerely believe car will run in the 11.50's with existing setup once I can nail down the traction. I am going to raise my shift points to 6600 with rev limiter on 6800 (everybody on the board seems to use this strategy, so I will follow suit). Currently, my RPM's are set at 6250. I am going to have my TB port and polish and hoping for some more ET there and MPH. I am seriously considering removing rear seats and purchasing lighter K-Member and front upper and lower control arms. Otherwise, this basically expains my setup. As stated, all my runs in the past have been done on Nitto's period. The fastest time my car has ever ran was 117.75. I forgot to mention car has Hal shocks front and back with front Hal drag springs, metco control arms, and TA torque arm.
In summary:
Reaction Time:.529
60'1.630
1/8 7.481 at 92.53
1/4 11.720 at 117.14
Lookout Raugh............Here I come <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" /> where am I <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
In summary:
Reaction Time:.529
60'1.630
1/8 7.481 at 92.53
Seems like Kent has the best time so far. 11.72 with ALL that stuff. Seems like we all should be doing a little better. I am getting wiery with these H&C people running high 11's with skinnies and LT's and such. I've seen Joe P cars run that with STOCK heads. Interesting! <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
LS1Tech Premium Sponsor
A lot of the guys running the G5 seem to have really low shift points. If it were me, I'd be winding it out to 6,800 after seeing a few dyno graphs from it. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I'm going to be shifting at 6,700 with my stock heads and Comp XE-R 224/112 LSA. <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
<small>[ May 07, 2002, 10:29 AM: Message edited by: Trevor D ]</small>
I'm going to have my limiter bumped from 66 to 6800 on Friday along with my LS1 Edit tuning...hopefully can get to a track sooner or later to see how it does after the cam, looking for 120+ traps, with slicks it should see an 11.7 or better...
C'mon guys! this is it...? Well, I was trusting that there was more on the forum running by now, if your out there, Post up and let us know.
Joe.
Joe.
