Debating between a TH400 or FLT Level 7
How much HP your expecting?
During initial tuning, the combo made 600 peak rwhp at 7300-7500 rpm on a mustang dyno, through an unlock 8"5500 stall. Will the computer be able to command shifts at those RPMS? I know with a manual Th400 you can shift to those RPMS and beyond.
How much power are you running through your FLT Level 6, and at what RPMS?
FLT is in my 02...540hp and shifting @ 6,700 (that's on the juice and spraying through the shifts)
Oh ok, you have it on your 2002 Z28.
FWIW, my old 355 nitrous combo dynode 535rhwp through the th400 and went 10.2@133-134mph at 3650lbs. Your car should go mid 9's N/A with the right converter.
My budget wouldn't allow for a proflite so I stuck with the 4l60e. I got the lower 1st and 2nd gear planetary ratios to help with traction and with the gear drop offs in the 4l60e.
Good thing with sticking with the 4l is you can keep stock shifter,Trans mount, driveshaft etc. cons are weight and cost to build
