Just Another LS Powered Altered Drag Car
23 T Altered
2005 6.0L LQ9
LS3 GM Ported Heads
Stock Short Block Except for Oil Pump
Enderle Bird Catcher with 80A Pump
Holley Hi Ram Intake
Disclaimer: I put this together in my garage, I'm not a professional, I'm posting this just to give someone ideas...
Haven't had it to the track yet.
After I spun the bearings in my Pontiac 463.
Straight from the junk yard
Reluctor wheel welding
Enderle 80A Cam Driven fuel pump
Home made cam spud.
intake adapter plate
drilling and tapping for fuel injections
tear down.
adding on to my u joint shield
drive shaft tube
drive shield
Gen V water pump on my Gen III
don't look to close, first time TIG welding stainless steel
headers up or down like an old school dragster
high speed poppet installed backwards to use as a fuel primer with a electric fuel pump for high flow priming
double protection
home made gen V electric water pump setup
2005 6.0L LQ9
LS3 GM Ported Heads
Home made cam spud.
tear down.
drive shaft tube
drive shield
double protection
The following users liked this post:
C5_Pete (10-24-2022)
thanks, i just didn't want people to start picking it appart because of this or that, welds not being perfect or something. Everything is done by trail and error, sometimes a whole lot of error!
Its still got the stock cam in it, so im figuring/ hoping it will run 9.80s or 70s. I'm gonna just get use to driving it agian, then next winter put the right cam in it, then it should run mid eights. Eventually I'm going to put a turbo on it, keep the mechanical fuel injection and see if i can get it to run halfway decent.
Nice job....I love seeing outside the box thinking/modding.
Out of curiosity why use a genv water pump? It seems pretty large and out there. Especially when there are many other electronic alternatives.
My original setup on my Pontiac I had a belt-driven fuel pump, but I like the clean look of a cam driven fuel pump. Then that created a problem with the water pump since the stock water pump wouldn't work. I considered a remote mounted water pump but then all of the fittings, hoses, where to mount the pump, and routing to the radiator, it just was going to be a bunch of messing around. When I saw that these gen V water pumps would clear a cam actuator which I needed to clear my fuel pump it would be a perfect setup. I really lucked out bc all the mounting bolts fit up from th pump to the block, and I only had to make little adapters to get the ports to match up. I also had a SBC electric pump that I robbed the motor from.
Thanks! Can't wait for spring to get there in the Midwest so I can see what it will do! I just got back from the March Meet and I've got he bug again...
The following 2 users liked this post by s1078:
C5_Pete (10-24-2022), Coach 02 A3 Z/28 (10-11-2022)
