LS Rear Engine Dragster Build
I have never done much, or anything at all when it comes to modding gas motors. Which is about to change. 2 years ago I picked up a roller 1997 chassis craft 245" rear engine dragster. I have a 6.7 cummins engine sitting here collecting dust, which i was going to run in this dragster. But now that times are a bit tougher, less money coming in, i feel like this cummins project will be another 10 years before i got it making a pass down the drag strip. It would need a bunch of chassis modifications and a lot of custom stuff.
So doing a bunch of researching, I quickly ended up with lots of good things about the LS motors. The car is setup for BBC/shorty glide, but i like more modern stuff when it comes to my vehicles. I don't want anything to do with a carb (although my buddy is trying to convince me to go carb, but that's just not something i'm interested in).
There is a LOT of stuff i have to research yet and figure out what all i want to do to the engine, but i found a guy with a 2005 6.0 LQ4 shortblock, a 2004 5.3 LM7 complete with wiring & ecm etc, and he's throwing in a long powerglide. Sooo as of now the plan is to run the 6.0 shortblock, stock crank and rods, maybe swap pistons for something forged. Then run the heads off the 5.3 and whatever else i'll need off of it.
Maybe it's easier to just make a list, if any of you guys have advice to add something or if there is something here that you would absolutely not run, or change, i'm all ears. I have a lot to learn about this platform yet.
6.0 shortblock
5.3 heads (will get pressure tested and decked) and whatever else i need off of it
Stock bottom end, some kind of forged pistons (haven't researched yet)
Sloppy stage 2 cam
Summit S475 turbo, probably run it at 10psi ish depending how fast the car ends up being
45mm wastegate
Turbo headers (i like things to look good too, don't want to run rusty stock truck manifolds lol)
Boost controller (haven't researched this yet)
Some kind of nice shiney looking intake manifold (same idea here, something good looking which also performs well)
ARP rod bolts
ARP head studs
Dual valve springs (open to suggestions on what's good here as well, there are so many options)
Electric water pump
Water to air intercooler, change out water and/or ice between runs
Oil pan or dry sump, another thing i haven't looked into yet, but i won't have much room under the motor for a big oil pan
Fluidampr or ATI harmonic balancer, leaning towards Fluidampr
Fuel pump, or 2 fuel pumps? open to suggestions here too
Bigger injectors, another item i haven't looked at yet
Like i said earlier there is so much i need to figure out yet, i just started planning a week ago, and spent countless hours reading on here and watching youtube. Hoping by sharing my build that i can learn some more from guys chiming in. And at the end hopefully i can run this car down the drag strip round after round starting May 2021.
Thanks for reading guys, excited to start tinkering with this thing!
I'll add a few pics of the car, and the Duramax truck i've been running, won 2 wally's with the Duramax as well.
https://www.summitracing.com/int/parts/fti-bpg4s
I'll check out the Holley high ram, and F body oil pan.
Thanks for your suggestions, appreciate it!
With this engine going in a dragster, what is left that needs vacuum?
Wasn't gonna change out the rods, unless absolutely necessary? The 6.0 rods will live at 700hp in such a light car no? I'm not against aftermarket rods either if i have to. If i have to upgrade them then i may as well get something better than a slight upgraded stock set.
I used to go 8.40's 162 mph with a 427 BBC. injected alcohol. I know you will go high 8's with a turbo on a 6.0l LS.
