Anyone have any experience mounting Lexan windows onto stock doors that have been gutted? I own a pair of fiberglass VFN doors, but decided to use my stock doors that were gutted. I have the frame kit already, just curious how people are mounting the bottom of the glass on the stock doors.
I plan on installing Lexan for the front and rear once I start to strip my car but no plans to remove the front or rear bumper supports. My door has manual windows so I take it the Lexan door windows would need those internal parts? BTW nice build you got going on there!
Thanks. I had front glass on my last F-body. This one will also have front and rear. I am just curious how people have mounted Lexan with the stock doors. There isn’t anything to mount the Lexan to on the bottom of the door like the fiberglass doors.
Thanks. I am just curious how people have mounted Lexan with the stock doors. There isn’t anything to mount the Lexan to on the bottom of the door like the fiberglass doors.
I am too. I bought a pair of the glass vfn doors too. Wow I was highly disappointed with the fitment. We have that same hood and hatch and they fit perfect. After completely gutting the stock doors we were shocked on how light they were so we weighed them. To our surprise they weighed very close to the same as the vfn's. And they fit perfect with the seals too, so we kept them. We are going to be loosing weight this winter and want to get rid of the crank up mechanism and the glass and go to the lexan too. I was wondering if you could just get one of those kits and get it to work also. Hopefully you can. Definitely interested to see what you come up with. We are going to do the same thing to the front too. We have a lot of weight to loose. We want to do the firewall and carbon roof as well. Your car Looks Killer. Great Job!!! Going to be sick as **** when you get it done.
Appreciate it. We will see what we can come up with.
I’ve tried to do this and unfortunately the only way is to make a lip to put on the door to attach the glass to, you can do it and panel bond a small sheet metal lip along the edge to attach the glass to but it looks hokey, to the point I would probably revisit your vfn doors and try to work the fitment.
fwiw I just installed a set of glasstek doors and other than the bottom of one needing to be brought out a little to get the alignment better, they fit decently.
the hinges have a lot to do with the fitment, personally I like the mcamis ones as they are pretty strait forward to install and are light/strong... same with his latch for the doors. Just be ready to modify/remount the door striker as it will have to be shifted outwards to work properly.
Does anyone know how close to the edge of lexan that you can drill for mounting bolts? I have a truck that im building with full frame doors that have a 1/2 lip where the window weatherstrip would go that I can mount too. minus about 1/8" for gap.
That is awesome. Who's widow kit is that? Besides the angle pieces, did you make the rods going to the inside of the door?
Thanks, It's a Racecraft window kit. The kit comes with the two J rods and a variety of mounting tabs. The window frame is complete but holes need to be drilled through the lexan to mount the frame to the window. Then mock up the window, figure out J rod locations and tabs and weld them together. You also end up putting a bend into the J rods to get the contour of the window close to the body curves.
