Drag Racing Tech
FMS 346ci N/A Record 10.16 @ 132 MPH !!!
Old 07-18-2004, 11:39 AM
NumberOneSled's Avatar
Originally Posted by GIZMO
Nice times, but what makes it a record? Do Stockers not count?
8 1169 Bo Kenney, Manassas VA, '01 Firebird 10.060 131.81 131.81
That run was last nite at Milan. There are several other 346 LS1 cars that have run in the nines.
No offence meant.
Best Regards,
Daren
Any truth to this?
Old 07-18-2004, 12:11 PM
PaiN's Avatar
Damn thats freakin impressive Lee! Especially when your fighting gremlins!
Awesome man!
Old 07-18-2004, 12:12 PM
gator's 99TA's Avatar
there are 9 second NHRA stock eliminator cars - namely al corda, the record holder. but ls1tech doesnt consider the S/E cars for internet records, but looks more for street type cars. admitidly it is a very fuzy line at this point with the fastest cars on this board. besides i havent seen many S/E cars driving legally with tags and insurace in a while Lee's car is that.
Old 07-18-2004, 12:48 PM
racer88's Avatar
Originally Posted by MechMan
Congrats lee
If Im gonna loose a race Im glad it was that one.
Your car just took the **** off on me.
lol I had the best seat in the place to watch that run
You looked awesome out there too Brian you guys were the badass of all 4th Gen Fbody's out there last night (except for when I made a pass LOL ) that's for sure the crowd loved you two every time you both lined up.
Old 07-18-2004, 12:50 PM
minty's Avatar
Awesome time but you probably DONT NEED A NEW MAF. There is a fuse that blows under the hood. its a 10 cent fuse and happened to my car. That is what the P0101 code is and check that first. Its a yellow 10 amp mini fuse under the hood. make sure you check BEFORE you go swapping a MAF and it doesnt fix it.
Old 07-18-2004, 01:18 PM
WILWAXU's Avatar
Congrats Lee!
I bet the numbers at Thunder Shootout are going to be unreal!
Old 07-18-2004, 01:21 PM
FEAR THE LS1's Avatar
We all know about the NHRA stock eliminator cars and how fast they are, but we don't consider any of them relevant in our world on here. My car is not a stock eliminator car and couldn't be compared to one. I would NEVER pass NHRA tech for any "stock" race they have because the rules are very specific. My car is a 2002 SS, that I have done all the work on myself. Every single part on my car was purchased from sponsors on this board. There is nothing stopping anyone else from building the exact same setup I have or better from all the sponsors on here. As far as our little world is concerned we all have our own little system for tracking whos the fastest with each type of setup, bolton only, cam only, 346 NA, 346 + PA, any cid NA LS1, etc etc.
Yea, while trying to chase down the possible cause to my problems, I've done the following:
Cleaned the MAF
Replaced the MAF connector on the wiring harness
Checked all the fuses
Checked my PCM tune
The only thing left is the MAF itself I guess. I did a search on the code here on the board and have been reading up on everyones solutions.
Thanks for the tip though!
Lee
Old 07-18-2004, 01:42 PM
theblur98ss's Avatar
Awesome runs. I was getting that code with an 85mm maf and it was the connector. I ended up just cutting the connector out and spliced the wires solid.
Old 07-18-2004, 01:43 PM
BIGBOS's Avatar
Sweet Jesus.......
Congrats on the new best......I'll never forget that wheelie at NvS.....that car is FLYING
9's are right around the corner
Old 07-18-2004, 02:05 PM
badass 2002 z28's Avatar
Awesome times!
before the end of the year NA 346's are gonna hit the 9's
Old 07-18-2004, 02:22 PM
Futral's Avatar
CONGRATS Lee Glad to see you progressing down there in that weather!
Just a little more and your there man
Old 07-18-2004, 02:49 PM
  #32
Hardtop's Avatar
Congrats. Awsome time with that DA. You've got to get that car in some cool dry air this fall.
Bruce
Old 07-18-2004, 03:33 PM
  #33
Shorty Director
VINCE's Avatar
Congrats LEE!!!!!
Old 07-18-2004, 04:02 PM
  #34
NastySSoo's Avatar
Congrats again Lee! I had the pleasure of watching you and Brian race. BTW, at the time of the race it was 79*, 74% hum., and baro was 29.95.Awesome Lee
Old 07-18-2004, 04:08 PM
  #35
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,141 Likes on 741 Posts
Congrats!!!!
Is that thru mufflers? I think once you run a 9.xx you should slap on some mufflers and some DOT tires and do a 25 cruise to show it's a street car.
Old 07-18-2004, 07:26 PM
  #36
Congrats!!!!
Yes that was with true dual 3" exhaust, xpipe, and 2 bullet mufflers.
Old 07-18-2004, 08:23 PM
  #37
Navy David SS's Avatar
Lee
1st congrats on the time. Awesome
2nd - I had the same problem, same code. The fuse was blown. Why? Driver's side O2 sensor had "rubed" threw causing a short, that blew the fuse. You need to fine the short.
Again good luck. With better air, you'll do 9's.
David
Old 07-18-2004, 08:58 PM
  #38
BlueSix's Avatar
The fuse isn't always the culprit for that code. My buddies car had the same code, and the entire MAF needed replacing. Now his car is stock, and your's, Lee, is a little less so. But i do feel that replacing your current MAF would solve the problem, try a ported stocker.
  #39
BlueSix's Avatar
Oh yeah, congrats on the ***** to the wall ride!
Old 07-18-2004, 09:06 PM
  #40
ATVracr's Avatar
Originally Posted by Navy David SS
Lee
David
Same with mine header burnt through the wire... kept blowin the fuse.
Check the wires. good luck and Nice times
