Drag Racing Tech
My crank pulley fell off last night!
Old 09-19-2002, 08:51 AM
GeorgeC's Avatar
Default My crank pulley fell off last night!
At least now I know why the car has been wanting to sling the belt off... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I did a burnout, and as soon as I let off the gas, I saw the check gages light come on, and saw the voltage drop on the voltmeter. I knew that it had tossed the belt again so I backed off the track and put the belt back on. 2nd try, same thing, but this time I heard a clunk. Evidently the crank pulley bolt had worked itself loose somehow and fallen out (this probably happened last Wednesday). With nothing holding it on, the crank pulley itself eventually just fell off.
Nothing looks damaged, so I think it will be fine once I get a new bolt. I can't remember if I used thread locker on the bolt last time, but I'll be sure to do so this time!
Obviously, I got no tuning accomplished last night...
Old 09-19-2002, 09:03 AM
Super Moderator
Reckless's Avatar
Default Re: My crank pulley fell off last night!
Dang! Good thing it happened at the line.. Could've been real ugly otherwise. I reused my last crank bolt with red loctite and haven't had any problems at all.
Old 09-19-2002, 09:12 AM
GeorgeC's Avatar
This wasn't the first time I've reused one. I think I forgot to squeeze some loctite on it.
I have 3 brand new ones one the way (should have them tomorrow morning) <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 09-19-2002, 09:16 AM
Skelton's Avatar
George, have you considered pinning the crank pulley? You do turn some high rpms.
Old 09-19-2002, 01:50 PM
GeorgeC's Avatar
Right now I still have the ASP aluminum underdrive pulley. I do want to put an ATI damper on the car in the future. There is no provision on the ASP pulley. I'm concerned about the crankshaft snout. How would you put a pin in it?
Old 09-19-2002, 04:41 PM
ROB'S SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong>Ah reused the crank bolt bad boy!!! I think a used one won't torque all the way so the other bad thing is that the pulley might be over a few millimeters and it can throw belts for that reason too.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">according to the boys at MMS, its not as bad as you think. sense the bolt isnt a torque to yeild bolt, it can be reused. i think its in chevy high performance. maybe the new one? they are doing a bolt on ls1 and they changed the pulley and thats what MMS had to say about it. ill look at work for the mag and get a pic and the rest of the article.
Old 09-19-2002, 05:18 PM
Adkoonerstrator
XLR8NSS's Avatar
There is some info(picture also) on ATI's website about the fixture/kit. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
ATI damper pinning kit
It looks like you might even be able to use it with the stock damper. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
John
<small>[ September 19, 2002, 05:19 PM: Message edited by: XLR8NSS ]</small>
Old 09-19-2002, 05:21 PM
GeorgeC's Avatar
Ahhh... Now I see. The picture in my head was a little different design.
I think I need to get the ATI damper and the pin kit!
Thanks for the link!
Old 09-19-2002, 06:41 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
damn George, sorry to hear you had bad luck last night, at least it didn't happen on saturday night! Hopefully you'll be back to pushing buttons in no time!
Derek <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old 09-19-2002, 07:33 PM
Pathological Modifier
Ryan K's Avatar
BTW, the crank bolt IS a torque to yeild bolt. I can pull out the book if you would like. And with out a flywheel holding tool its a major PITA to get that 120 degrees!
Ryan K.
Old 09-19-2002, 07:42 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Yes it is. It's possible that George needs a keyed assembly or something but old crank bolts just stretch and I'm sure they don't see all the way. I had a buddy who decided that he was tired and did not torque his all the way and it was not seated all the way and would throw belts at WOT, stuff would walk off.
Old 09-19-2002, 07:43 PM
ALLBORENOSTROKE's Avatar
If you are running an ASP pulley you might need to get a new one.I had the same problem with my car,I tried a new bolt and it still fell off.Sometimes if the pulley is taken off and reinstalled a couple of times it has to be replaced.
Old 09-19-2002, 07:49 PM
Adkoonerstrator
XLR8NSS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ryan Karasek:
<strong>BTW, the crank bolt IS a torque to yeild bolt. I can pull out the book if you would like. And with out a flywheel holding tool its a major PITA to get that 120 degrees!
Ryan K.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">BIG Screwdriver thru the flexplate and a two foot extension on a 1/2" breaker bar. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
BTW, ATI (supercharger not damper company) sends a reusable damper bolt with their blower kits. For people always slinging dampers off(George C <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> ) a reusable bolt(non TTY) and 1 hardened washer would probably be better.
George - No problem on the link! Get that puppy into the 9's <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
John
Old 09-20-2002, 12:24 AM
LS1Tech Co-Founder
Old 09-20-2002, 12:42 AM
GeorgeC's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Y2K Blackbird:
<strong>George, have you considered pinning the crank pulley? You do turn some high rpms.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I was thinking of that... I presume you have to have a keyway machined into the crank snout, though. I don't want to pull the engine out and disassemble it at this point though.
If it can be done with the motor in the car, then I'd be all for it.
Old 09-20-2002, 12:51 AM
Adkoonerstrator
XLR8NSS's Avatar
What pulley do you have? ATI?
I think ATI has a crank pinning kit that allows you to pin the crank pulley while its on the car. I don't know if it will work with a stock pulley or not, probably not. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
John
Old 09-20-2002, 09:15 AM
30th TA 0219's Avatar
How much is that bad boy?!?! Was that just the template for drilling and installing?!?!
Old 09-20-2002, 09:48 AM
GeorgeC's Avatar
The pinning kit is just over $100. It looks like it comes with everything needed to drill the keyways and install the pins. The ATI dampers already come with the keyways, so only the crank would need to be modified.
Old 09-20-2002, 11:16 AM
Terry Burger's Avatar
Pinning is only for blowers. I doubt George's alternator has enough drag to spin the crank. Just put a new bolt in. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 09-20-2002, 05:35 PM
George, where would you go around here for that?!? Or would you do it yourself?!?! You need and ATI anyway spinning like you do, and it's legal at your speeds! But just curious also about notching a non-ATI pulley. Let us know what you decide. When you hitting G'ville again?!? Haven't seen the new motor run yet!
