Drag Racing Tech
Alignment for drag/street car?
Old Aug 26, 2004 | 10:03 AM
JS's Avatar
JS
Default Alignment for drag/street car?
I DONT want my car to be a total drag car but lets face it I've only put 11K Miles on it in 4 yrs.That being said,Should I do my alignment w/ME sitting in the car or should I do it w/o me in the car?
Also should I align it w/my race tires and the car setup to race or in street mode.I would think I should align it like I race it but I'd like to hear from Madman or other susp guys.
Madman helped me with my TQ arm and thats all done.I have the air bag at 25psi/RS shock tighter than left and the car seems to like the adjustment I've made but I still wanna redo the alignment for the front of the car.
Old Aug 26, 2004 | 11:18 AM
MADMAN's Avatar
LS1Tech Sponsor
Put the tires you plan on racing with on the car. Set the caster with as much as you can get. Usually 5-6 degrees. Camber at 0. Tell them to set both sides the same DONOT set the car up for road crown. Now for the important part. Set toe at 1/16th toe in at ride height. Then raise the front end up till the front shocks are almost extended, recheck toe. Then squat the front end like its under hard braking. Recheck toe. NEVER!!!!!!!! have toe out. If you do the car will hunt for guardrails.
__________________
www.madmanandcoracing.com
225-343-9029
Old Aug 26, 2004 | 11:29 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Brian, we have followed your advice for alignments and have done Magnus' car that way, and mine, and they have worked really well. We did our own.
Old Aug 26, 2004 | 12:07 PM
CHRISPY's Avatar
Great info madman!!
Old Aug 26, 2004 | 12:40 PM
JS's Avatar
JS
I have hiemed race style a-arms in my car chris and wondering if u do too.Reason I ask is there alittle more of a pita to setup.Chris did u sit in the car when u did the aligment?U did use a an alignment rack?
Thanks Madman,Gotta work on that this week.
Old Aug 26, 2004 | 04:15 PM
gomer's Avatar
A guy a work with runs oval asphalt and we were talking about alignment settings and this is what he says.
On oval half mile asphalt setups if the car is toe'd in it darts really bad on the straights.. they run 1/8 to 1/4" toe out to keep the car from darting when accelerating in a straight line. Would the same be true for a drag car??
Old Aug 26, 2004 | 06:49 PM
CHRISPY's Avatar
My alignment sucks ****. I need to have it done. (Havent done an alignment since I bought the car 5 years ago LOL!)
Old Aug 27, 2004 | 06:33 AM
MADMAN's Avatar
LS1Tech Sponsor
Oval track racing is totally different settings. You run alot of preload in the chassis to make the car turn. If we have to turn on the drag strip we are F%^&ed.
__________________
225-343-9029
Old Aug 27, 2004 | 08:38 AM
JS's Avatar
JS
Madman should I be sitting in the car when we do the alignment?
Old Aug 27, 2004 | 09:48 AM
MADMAN's Avatar
LS1Tech Sponsor
I usually have the drivers weight in the car.
__________________
225-343-9029
Old Aug 27, 2004 | 11:40 AM
JS's Avatar
JS
Thats what I thought,I'll still be able to street drive the car with this alignment?
Old Aug 27, 2004 | 12:41 PM
JL ws-6's Avatar
Race your car!
How are you guys doing the align. yourself? I thought that you had to have a rig to do that right? Any shops in CT that can do that type of thing?
Old Aug 27, 2004 | 01:29 PM
JS's Avatar
JS
Madman your settings are for a race car,u need road crown for street driving.
The car will wander if the roads uneven,I cant set the car up strickly for racing.
I wanna drive the car too
Old Aug 27, 2004 | 03:01 PM
MADMAN's Avatar
LS1Tech Sponsor
You cant have your cake and eat it to. The car wont wonder that bad on the road. I would rather have to hold the car straight on the street than try to knock the wall down at the track.
__________________
225-343-9029
Old Aug 27, 2004 | 03:29 PM
JS's Avatar
JS
I understand but it will wonder never the less...
I know I need to either say the is a more race than street,I cant have both....
But lets say I was setting it up to drive street/strip
Would u set it alittle bit different..
Old Aug 27, 2004 | 04:19 PM
MADMAN's Avatar
LS1Tech Sponsor
No.
Its not going to wander. All its going to do is pull to the right a little.
__________________
225-343-9029
Old Oct 11, 2004 | 08:49 PM
JNorris's Avatar
Moderator
Is the toe in spec for each front wheel or total toe in?
Thanks
John
Old Oct 12, 2004 | 08:17 AM
MADMAN's Avatar
LS1Tech Sponsor
Per wheel.
__________________
225-343-9029
Old Oct 12, 2004 | 09:40 PM
JNorris's Avatar
Moderator
Thanks
Old Oct 12, 2004 | 10:24 PM
SMOKIN01TA's Avatar
good info i needed to know about, thanks madman
