Drag Racing Tech
Spohn Torque Arm worth the swap?`
Old Sep 10, 2004 | 07:42 PM
Damage Inc.'s Avatar
Sweet Cheeks
Default Spohn Torque Arm worth the swap?`
I have an adjustable tailshaft mounted BMR TA now and it's been working great. My buddy wants to sell me his Chromoly Frame mounted Spohn TA for only $275. I checked it out and it's HEAVY! He says it's worth it's weight in gold and that it has a loop too, which is true.
My question is:
Is the Spohn the way to go for 10s? Is the Spohn a better unit? Any and all comments are appreciated. Thanks. PS, how heavy is the BMR? It was on the car when I bought it. Spohn is 28 lbs. Thanks.
Old Sep 11, 2004 | 08:42 AM
00sscam's Avatar
hell ya i will trade you my steel for thew chrome moly one that is a bout $500 part he ios giving away I say jump on it.
Old Sep 11, 2004 | 11:14 AM
bad2000ss's Avatar
My question is:
I'm sure most people will tell you to go with a MADMAN or BMR, but for the price, and the fact that it bolts in, the Spohn is a good deal. I didn't get a decent chance to compare it to the stock torque arm in respect to launches and 60' times because I twisted the stock one my first time out on slicks. I do notice that breaking is a lot easier. A lot less nose dive.
I do have a slight clearance issue with steep driveways. I have the torque arm for long tubes so it hangs low. I've hit it a few times pretty hard, so hard once I thought I ripped it out. It didn't even budge. I've heard lots of people say the body mounting points were a weak point, my experience is the exact opposite. It has held strong with no sign of any weak points.
The spohn body mount is REALLY noisey. It clunks and pops over bumps and pulling into driveways, but you'll get used to it. No matter what adjustment I try, or how much grease, or how tight or loose the front nuts/bolts are, its still clunks and pops. Then again, anyone who says their spohn torque are isn't noisey hasn't beat on it enough.
Old Sep 11, 2004 | 01:08 PM
JL ws-6's Avatar
Race your car!
I have a spohn tq arm on my car and I like it. The body mounting points proved to be strong, and the SLP subframes also tie into that same mounting point, tying everything up real nice. After the subframes went on, the tq arm noise seems to be more pronounced, but that's probably due to more solid mounting. I'd say go for it, I'm sure that you won't be dissappointed.
Old Sep 11, 2004 | 03:26 PM
Sweet Cheeks
Yeah, he said he paid $525 for it. I'm going to bolt it up today. Thanks guys.
Old Sep 11, 2004 | 07:12 PM
gettinthere's Avatar
I'll take your BMR, call me.
Old Sep 12, 2004 | 07:33 PM
Sweet Cheeks
Yeah, I'm getting the Spohn welded in within the next 2 weeks. The crossmember holes are covered by my DD SFCs. I'll call you Bri.
Old Sep 13, 2004 | 03:43 PM
DERTY's Avatar
The Bull
The Spohn TA works great. The question I have, what exactly are you getting welded in? There is nothing to weld.
Old Sep 13, 2004 | 04:00 PM
Sweet Cheeks
The crossbrace or driveshaft loop where the TA mounts to the body is supposed to use existing holes where the stock brace goes. Well, when I had my DD SFCs installed, they didn't quite line up with the holes and I just had them welded on. Now, having welded the SFCs, they cover the holes for the TA. So, I have to have the TA brace welded to my SFCs? You see? Would this be fine? What do you think?
Old Sep 13, 2004 | 04:16 PM
DERTY's Avatar
The Bull
That makes way more sense now. But, DON'T DO THAT. You will never get your transmission out of the car if you ever break it. With the mount welded in you'll never be able to slide the transmission back far enough to take it in and out. You should try to line up the brace and just drill holes through the existing SFC's. Then bolt and nut them together.
Old Sep 13, 2004 | 10:30 PM
What if it's already broken???
Old Sep 14, 2004 | 07:25 AM
DERTY's Avatar
The Bull
Then you'll never get it back in? lol
Old Sep 14, 2004 | 09:36 AM
Sweet Cheeks
I'd much rather drill and tap new holes, but how will I know the TA is straight and true? I think I'm going to have it done so I don't mess anything up. Thanks for your help.
Old Sep 14, 2004 | 10:20 AM
DERTY's Avatar
The Bull
It's all heim jointed, so if you're off a couple degrees you won't notice too much. Just try and clamp it up there so that it lines up. Even take the torque arm off the cross member so it's lighter! Then just do what you can to line it up and mark some holes. If you have the meat to tap the holes, great. If not you will likely have to bolt it in instead.
