How fast can a SI LS1 on a crazy N20 setup go?
Sweet Cheeks
How fast can an internally stock LS1 run with say a progressive wet/dry 2 stage or whatever on a slick? How much can you spray at a stock LS1 motor? I need to know if this kid's legit and what he should be running. He's been spraying it for a while so I'd assume it can be THAT big of a shot?
Thanks.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
How fast is he goin???? My fastest so far with longtubes, lid, ASP, TH400, converter, and suspension on a dual wet/dry spraying a 200 shot is the current record with a
10.28 @ 129 w/ a 1.42 60'
Should hit 9's once the weather cools down here.....just got a tighter converter (4600 on the T-Brake to 3600) and a 1-7/8 Kooks header due to the power falling off at high RPM's because of exhaust restriction.....the converter was killing the 3rd gear pull
Originally Posted by Dear John
That's sick! I'd didn't think you could do that
So for a punk kid on a ET Street on the street. Maybe 11.00?
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Fastest Stock Bottom End belongs to Icon Motorsports I believe 9.69
https://ls1tech.com/forums/single-digit-club/205514-9-69-stock-bottom-end-record.html
Are you asking true SI or stock bottom end. Those untouched SI numbers are sick! There's quite a few stock bottom end cars that are running very good numbers out there too
Icon set the bar for that.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Originally Posted by '01 WS6 TA
Raceweight was right at 3390....this was at the Pontiac High Performance Magazine shoot back in May....the DA was +2500....the article should be in the January '05 issue.....
TTT
TTT
LS1Tech Co-Founder
Hacker Joe went 10.81 in 1999 on two stages, @ like 3800 r/weight. Went 11.4@116 on one stage.
Dave Purlee went 10.5 over the next two years, he posted at Silver LS1!.
Sean Freese aka KechMe I believe went 10.3 after that.
And it looks like someone went 10.2's.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
And it looks like someone went 10.2's.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Mike
TTT
TTT
Friend of mine just dyno'd his 98 TA on a 2 stage (100 dry/100 propane wet) setup. He has a bone stock motor except for my old TR224 cam and Mac's. It made 358 rwhp NA and 548 rwhp at the wheels on the spray, untuned. Pretty sick if you ask me.....
