Drag Racing Tech
Getting the '69 track ready (pics)
Old 11-20-2004, 05:39 PM
LS1Tech Co-Founder
Nine Ball's Avatar
Talking Getting the '69 track ready (pics)
Sure, its a "Pro-Touring" car, but with a simple wheel and tire swap, and the addition of a new 6-point rollbar, it sure does look different. I had to reposition the rear shocks upwards a bit, and slightly grind some casting corners off of my fancy front brake calipers, but everything fits now.
28x10x15 Hoosier slicks
15x10 (5.5 backspace) Weld Pro-Stars in the rear
15x3.5 Weld Pro-Stars in the front
https://ls1tech.com/69Camaro/drag01.jpg
https://ls1tech.com/69Camaro/drag02.jpg
https://ls1tech.com/69Camaro/drag03.jpg
https://ls1tech.com/69Camaro/drag04.jpg
https://ls1tech.com/69Camaro/drag05.jpg
https://ls1tech.com/69Camaro/drag06.jpg
These are definitely the biggest tires you can fit under those stock quarters. I even had to roll the fender lips to make them fit!
Rollbar photos: (designed and installed by MADMAN)
https://ls1tech.com/69Camaro/caged1.jpg
https://ls1tech.com/69Camaro/caged2.jpg
https://ls1tech.com/69Camaro/caged3.jpg
If the weather clears, and I get some time, I might hit the track tomorrow :3gears:
Tony
Old 11-20-2004, 05:42 PM
Big Mike's Avatar
That car is just to "F"ing sweet! Looks so much more "appropriate" with slicks and skinnies on!
Old 11-20-2004, 05:51 PM
Navy David SS's Avatar
Very nice. Loved the car at Thunder Shoot Out. It was really nice meeting you.
David
Old 11-20-2004, 06:19 PM
LS1Tech Co-Founder
Nine Ball's Avatar
I know what you mean Mike, I've always loved big-n-littles on a 1st gen. Of course, it stands out much better on the 17s though, as there are a ton of 69s on Pro-Stars.
David, these are the wheels/tires I was planning on running at Thunder, until I realized the rear wheels I had were the wrong offset (6.5 bs). So, I had to order new ones, which finally showed up this past week.
It will be fun to race with traction again!
Old 11-20-2004, 07:14 PM
7 Second Club / STF Veteran
68maro's Avatar
car looks sweet man but i have a 28x12.5 et street under mine and the fenders and wheel wells are stock haven't rolled the lip or anything and at one point i had a 28x13.5 under so i don't know why you had to roll yours. but the car does look really good. what are you running?
Old 11-20-2004, 08:28 PM
Motorboater
SilverGhost's Avatar
that turd don't need a 28" tire
so whats the prediction for track results then bro..tranny still acting up or no?
Old 11-20-2004, 08:35 PM
99ssleeper's Avatar
I really like those seats!
Old 11-20-2004, 10:00 PM
granitemonkey's Avatar
Old 11-20-2004, 10:26 PM
LS1Tech Co-Founder
Nine Ball's Avatar
ET Streets aren't as wide as real slicks. On my previous car, 26x11.5 ET Streets weren't as wide as my 26x10.0 slicks. My car is also lowered, I'm sure a wider tire could fit if the car was at stock height.
Sean, tranny still acting up, but it typically goes into gear okay. Getting it out of gear can be a problem sometimes. I need to rebuild my other one and pull this one back out to look at it also
Old 11-21-2004, 12:33 AM
DMcRacer's Avatar
Looks pretty mean with those wheels That is a sweet ride
Old 11-21-2004, 01:13 AM
BIGBOS's Avatar
That car looks mean.....
Old 11-21-2004, 02:10 AM
boosted03cobra's Avatar
that thing is bad ***
Old 11-21-2004, 08:06 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
A 28 x 12.5 x 15 et street has almost the same dimensions as a 28 x 10.5 x 15 slick. I've seen numerous 28 x 10.5 slicks on early Camaros and that's pretty much all that will fit without going outside the body lines unless it's mini-tubbed.
Tony, car looks sweet in race trim! I'm sure you musta cringed a little to put a 6-point in a show car Something I noticed though, not that I'm doubting madman's work. The door bars look a little low to pass tech. Great if they do though, all the easier to get in/out of the car. Did you consider a swing out?
Derek
Old 11-21-2004, 08:27 AM
LS1Tech Co-Founder
Nine Ball's Avatar
I can move the seat back and the bar passes between my shoulder and elbow, so it is legal.
I didn't cringe at all getting the rollbar installed, I had it planned all along. I didn't go with swing outs because I wanted to stiffen up this loose chassis. 1st gens are very loose compared to 4th gens, it needed all the help it could get. I also have welded in subframes now as well. Of course, some of the other staff members here thought I was a nut to put a cage in a "showcar". But, I hope to run 9s in this showcar (on nitrous), to show other showcar builders how to do it
Old 11-21-2004, 09:21 AM
7 Second Club
Cool, I understand the roll bar philosophy on stiffness. I went swing-out b/c already had the sfc installed and still drive mine plenty and hate climbing over a bar. yours looks clean though. Good luck with getting it hooked up and some quick times.
A little but when is your car going to be in Popular Hot Rodding?
Old 11-21-2004, 01:24 PM
JS
JS's Avatar
IMO,It just looks better with the Welds..
Thats car is beautiful Tony,Good luck at the track.
Old 11-21-2004, 01:40 PM
LS1Tech Co-Founder
Nine Ball's Avatar
It should appear in PHR in 2-3 months typically. They already submitted the write-up to the publisher a couple weeks ago.
Old 11-21-2004, 07:37 PM
hondo's Avatar
looks like you put some traction bars on that RACE CAR hehe
what kind?......that thing looks so f-in bad *** with slicks and skinnies on it..nice
Old 11-21-2004, 08:56 PM
gator's 99TA's Avatar
looks awesome. i love that deep dish look with that 5.5BS on it. have fun with it.
Old 11-21-2004, 09:11 PM
next's Avatar
Tony,
The pro touring look is cool, but the new look is bad ***! With those tires and the Caltracs you'll get that thing to hook in a car wash.
