Drag Racing Tech
front skinny backspace question...
Old Dec 4, 2004 | 09:49 AM
Slow Z28's Avatar
Default front skinny backspace question...
anybody try and fit a 2 1/4" BS rim on the front of our cars? bogart? weld one piece magnum/alumastar?
Chris
Old Dec 4, 2004 | 10:24 AM
y2khawk's Avatar
I've got 2.25" BS alumastar one piece up front, strange drag brakes.
Old Dec 4, 2004 | 10:40 AM
Slow Z28's Avatar
do you think it looks better than when a 1.75 BS is on the car? (besides the obvious wheel itself looking better part)
Chris
Old Dec 4, 2004 | 10:57 AM
y2khawk's Avatar
well, i ran a 1.75" BS prostar and 5/16 spacer w/ the stock brakes. The outer edge of the tire was even or just a tad out of the wheel well then. the 1.75 and spacer effectively makes the backspacing a little less then 1.5".
I wanted to suck the wheels in, and going to 2.25 moved them in about 3/4". I like the look much better
The strange brakes use a replacement spindle and aluminum hub, they appear to place the wheel in the same location as stock. So the wheel moving in should be solely a function of the back spacing.
I can probably get a picture of how far in they are if needed.
Old Dec 4, 2004 | 10:58 AM
y2khawk's Avatar
infact, I still have the prostars and spacers. I could snap a picture of all 3 setups if i get motivated
Old Dec 4, 2004 | 12:10 PM
Slow Z28's Avatar
haha, i can't make you do that. but for research purposes of others in same situation might be of benefit, haha j/k
That's good to know though. Thanks
Old Dec 5, 2004 | 01:53 AM
z-ya's Avatar
Convo pro 15x4 2 5/16 backspace, sold my 15x3 1/2 1 3/4 backspace to use them.
Required some caliper grinding but fixed the getto wheel look it had before.
Old Dec 8, 2004 | 01:13 PM
1BADAIR's Avatar
I have 1.75 inch back spacing with the eibach prokit and I am always worried the tire is going to hit the fender if I get the car to launch hard
Old Dec 8, 2004 | 04:13 PM
slow3hoe2's Avatar
pics of what? 1.75" bs pro stars? or 2.25" bs prostars? cuz ive been trying to do the same thing....move the wheel in.
i have 3 1/2" 1.75 bs draglites with a 5/16" spracer and the wheel hangs out. The only draglite or prostar i could find to move the wheel in is a 15 x 5 with 3 1/2" bs ....that would let me still run the spacer...but move the wheel in 1/4"...plus the extra rim width on the inside would suck the tires in a little more...the tires look like a set of toothpicks under the front now...so i thought this might be a good idea. is this a good idea? i guess the only weight difference would be another 1 1/2 inches of rim.
do they make a 15 x 3 1/2 with 2.25" of bs in draglites?
Old Dec 8, 2004 | 04:49 PM
TOSTO RACING's Avatar
I have bogart pro stars 15x3.5 with 2 1/2 inch backspace tucks in very nice.
