Drag Racing Tech
Homemade Torque Arm-Pics
Old Dec 15, 2004 | 05:46 PM
S_J_H's Avatar
Smile Homemade Torque Arm-Pics
There are many nice T-arms available but I thought I would try building one myself. I figured I could do a decent job, save a few bucks, learn a thing or 2 and practice at my beginner level fab skills .
After looking at all the available arms for some building ideas, I went with a short arm, shackle design. The Arm is built from mild steel tube, 1.3" OD, .133 ID, nothing special. The rear plates are 3/8" and 1/4". The total length of the arm including the Moser mount is 35" from the axle centerline. Should be good for a nice hard fast hit. I had built the arm with a rear adjuster at first. But as I messed with it, I found it really was not needed so I re-did the arm to eliminate the adjuster. Since the arm is pretty short, lowering the front pivot to adjust pinion angle does not make much of a change to the geometry like it would with a long arm. So I made a few shackles with preset pinion angles. It's pretty fast and easy to change them out. The shackle in the pic gives me -1' of angle.
I decided against a spherical bearing up front on the arm for a few reasons. The front bushing on the arm is solid with poly isolators.The lower bushing is poly.The entire arm is welded as 1 piece, although I kept the rear bolts in anyhow. I triangulated it with some plate but that was probably overkill.
The tube part of the cross member is actually a modified front sway bar that is 1" by .190 ID. While preparing to build the cross member I spotted my old sway bar and thought the bends and width sure looked like what I needed to tie into the roll bar and clear the exhaust and run tight to the floor pan for clearance. I added some plate to the ends and added 1/4" bar stock to stiffen everything up from any unwanted flex. The lower bushing mount is 1/4" thick and externally and internally welded to the tubing.The cross member is tied directly into my roll bar main hoop through the floor. It's a very strong unit and it would take a lot to flex it. Arm and cross member weigh 26lbs.
Steve
Old Dec 15, 2004 | 05:57 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Wow nice. I did not know you could weld like that.
Old Dec 15, 2004 | 06:09 PM
kp's Avatar
kp
great job as usual steve..
But my wife would kick my *** if I laid that thing on our new floor
Old Dec 15, 2004 | 06:28 PM
JS's Avatar
JS
sweet...
Old Dec 15, 2004 | 06:54 PM
NLang's Avatar
When I looked at the underbody shots, I was thinking, 'what is that bohemeth tube running down the length car'. At first glance it looked like a fabbed driveshaft I finally realized what it was (the y-pipe)...
The tq arm looks nice. I just put one together as well. That was a good idea using the swaybar-for sure an original. It didn't even cross my mind...
Old Dec 15, 2004 | 07:12 PM
SilverGhost's Avatar
Motorboater
very impressive!!
let us know how it works
Old Dec 15, 2004 | 11:34 PM
Birdie2000's Avatar
Looks very nice!
Is it possible to get some pics that better illustrate where the crossmember attaches?
Old Dec 16, 2004 | 12:01 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Everything looks pretty beefy except for those two plates that join the arm to the cross member. Maybe use thicker gauge plate, or even better, box those in and make them a single unit.
Old Dec 16, 2004 | 08:47 AM
S_J_H's Avatar
Thanks Guys. It was sort of fun building it.
Kevin, I installed my flooring myself so I feel I'm entitled to put anything I want on it .
yeah it's a big Y Pipe I made running into a 4" mufflex system .
I'll try and take some more pics of it. I could have welded it as I have plates under the car already welded for the rollbar. I decided to just bolt it through the plates into the rollbar plates so It could be removed if necessary.It's bolted with 4 bolts each tightened to 110 ft/lbs of torque.
Well I agree, if there is a weak link it's the shackles. They are 3/16" thick and since the load on them is pretty much just a up/down motion and distributed through 4 holes I did not see a need to box it. Plus it let's them flex a bit for lateral motion. I checked out how the arm responds to one wheel being jacked up to simulate lateral motion. If the car was a road racer I would for sure use a sperical bearing up front to allow the arm bind free lateral motion and use beefier shackles. I can fit a huge single bearing to replace the poly bushing on the cross member with a load rating equal to two 3/4" rod end bearings.But I think for my intentions for the car it's not needed.
Looking at BMR's and Wolfes arms, the shackles they use don't appear any beefier.
I'll keep an eye on them and If I see any reason to upgrade them I will.
Next project is a rear drag sway bar.
Steve
Old Dec 16, 2004 | 10:50 AM
Fireball's Avatar
the Instant center of that T/A is pretty far back...Its going to want to hit very hard I think...hopefully it don't put you on the rear bumper
Looks sweet though...we are going to build a custom T/A for mine this spring
Old Dec 16, 2004 | 11:09 AM
S_J_H's Avatar
I have to go and measure again how far from the ground the front mount is. I think it's at around 10" which gives me somewhere around 135% Anti-Squat.
I had looked into building a set of short ladder bars like the Pete Z setup. But decided against it. Now those REALLY move the instant center to the rear.
Old Dec 16, 2004 | 11:33 AM
Camaro_Zach's Avatar
im very impressed and very jealous of your talent and tools you have available to you. good job!
Old Dec 16, 2004 | 12:13 PM
Fireball's Avatar
Steve...check your pms
Old Dec 16, 2004 | 12:14 PM
S_J_H's Avatar
Thank you for the compliment. I just like doing my own fab work when ever I can.The more you do the more you learn. I'm still a hack at this stuff but I'm learning.
I am only using a 115 volt 155amp Century Mig for a welder. I have a modest amount of tools and do it all in my garage. The tools used for this project was my mig, chop saw, drill, angle and die grinder and shop press. Heck I even used my home oven on self cleaning mode to help stress relieve the arm some after welding it - 880'F for 4 hours.
The Wife loved that!
here's a couple more pics of the cross member showing how it fits pretty tight under the car and bolted into the rollbar plate-
I also made some LCA relocate brackets for my Moser 9"-
Steve
Old Dec 16, 2004 | 12:32 PM
Race Car Driver's Avatar
11 & 7 Second Clubs
How many total hours do you have in your arm?
Old Dec 16, 2004 | 12:47 PM
S_J_H's Avatar
well it took me 1 week to make the arm and the cross member so I have a lot of hours in it. But much of the time spent was measuring and sort of figuring things out as I went.
Old Dec 16, 2004 | 01:39 PM
11 & 7 Second Clubs
I admire you for investing that much time in it. I, on the otherhand, do not have and cannot afford such time and would simply pickup the phone and order one.
Old Dec 16, 2004 | 02:14 PM
kp's Avatar
kp
I'll measure the BMR shackles if I remember but they look like 3/16, I think Steve'e look thinner because they are bigger and not rounded off..
Old Dec 16, 2004 | 05:44 PM
S_J_H's Avatar
I'm the sort that enjoys building and fabbing as much as racing, so the time spent was enjoyable and rewarding for me .
as to the brackets, I made the shackles from the same 3/16" plate I made the LCA drop brackets from that are pictured above, those pics gives a little better sense of the thickness.
When you consider the entire stock t-arm is only about 1/8" thick stamped steel, then two 3/16" plates for the front pivot should workout I guess.
Steve
Old Dec 16, 2004 | 06:12 PM
NA$TY-TA's Avatar
KP is that the Extreme or Track Pak????
Awsome job fabbing it up yourself......
Kyle
