Thinking about manual rack
Baer brakes sells these baer tracker kits for adjusting bump steer. You might be able to use these with your manual rack kit or they may be willing to just sell the tapered stud adaptor or point you in the right direction.
www.speedwaymotors.com and search on this part number: 91636055-gm. As long as the taper is the same it should be what you're looking for.
BTW, it is obvious why the Aerospace brakes are less expensive than Strange. Had to do some cleanup with a tap and enlarge the mounting holes in two of the rotors. You can see one place where the jig came loose and the tool walked. But, they look to be quite serviceable and I didn't have to put $500 worth of time into them, so I am not bummed.
As said, this is assuming you are comparing stock rack that has been "looped" and the stock linkage vs. the manual rack, it's heavy steel support bracket and hardware that is to be welded to the k-member, bump steer ends, and the linkage.
I had heard 5-10#'s and was very skeptical and confirmed this when I got my manual rack kit last month. However, it's a VERY nice piece and am pleased with it and will install it whenever it's not so damn cold.
Assuming you are already "looped", look at purchasing it for driveability, NOT for weight savings. There are far better ways to spend $700 (rack kit, shipping, and an alignment) if you still need a k-member, etc., etc. I am not knocking it, just saying it'd be later on my purchase list if I was just getting started. Take care. Dave
