Drag Racing Tech
is a sfi bellhousing required
Old Mar 7, 2005 | 08:01 AM
Fireball's Avatar
Originally Posted by smokinHawk
but it helps and is better then nothing
im hoping the ls1tech series wont be to strict about this cause there will be alot of people not racing.
its easy to get on and not that expensive. it will work for me untill i can fit the belhousing into my budget, a cage needs to come first.
safety equipment is safety equipment. There is no order or importance that says you need this now but this can wait.
I'm gonna be looking at M6 cars in my class, if they don't have it...I'll protest. If I carry the extra 30lb to be legal...then so should everyone else
Old Mar 7, 2005 | 03:11 PM
redline2k's Avatar
Originally Posted by Fireball
when it originally came out it hadn't been SFI certified yet. The Mcleod 8710 is now SFI certed.
Thanks for the help I ordered mine today. Hopefully my car is good now to 9.99. By the way what class are you running in? I was thinking about the 10.90 class.
Old Mar 9, 2005 | 11:32 AM
Fireball's Avatar
I'm gearing up the Superstock class...
Old Mar 9, 2005 | 12:11 PM
MIGHTYMOUSE's Avatar
if they dont make one that fits my car -> won't buy one
i thought i read in the rules that the sfi rating is void if the bellhousing has been modified. maybe not.
Old Mar 9, 2005 | 12:51 PM
Fireball's Avatar
you are correct...can't modify the bellhousing in any way...but...
Mcleod's fits in w/o any modifications required to the bellhousing. needed some grinding of the oilpan/rear cover due to the design of the LS1 and the requirement of a steel plate behind the flywheel.
look here: https://ls1tech.com/forums/manual-transmission/258875-mcleod-sfi-bellhousing-installed-pics-info-within.html
