Drag Racing Tech
is a sfi bellhousing required
Old Feb 5, 2005 | 11:44 PM
SMOKIN01TA's Avatar
Default is a sfi bellhousing required
to run in the tech series, just was thinking about that, i have no clue and didnt plan on doing one any time soon.
Old Feb 6, 2005 | 03:09 AM
44mag's Avatar
im not sure about your question but as much power as your making and as fast as your running i would get one just for my own safety. if the flywheel come through it would tear you a new one!
Old Feb 6, 2005 | 09:40 AM
The Juggernaut's Avatar
I think Fireball just did one, it's a good idea.
It's better than having the clutch explode and cutting you feet off.
Old Feb 6, 2005 | 10:53 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Who makes one for the T56?
Old Feb 6, 2005 | 10:55 AM
SilverGhost's Avatar
Motorboater
tony i believe McCloud makes the one for our cars now..
Old Feb 6, 2005 | 01:26 PM
SMOKIN01TA's Avatar
yea,i knew fireball did one, just wanted to know if it was required or optional
Old Feb 6, 2005 | 03:32 PM
kp's Avatar
kp
NHRA is 11.99 and quicker for a bellhousing, if NHRA rules are enforced at the event then yes you need one. Dont know whats going to happen with C5s though, kind of a can of worms so to speak. I know someone makes a trans blanket type shield that goes around the bellhousing but I dont know if its legal or not.
Old Feb 6, 2005 | 03:34 PM
TOSTO RACING's Avatar
11.99 1/4 -7.49 1/8 or quicker in NHRA rulebook
Old Feb 6, 2005 | 05:16 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Anyone got a link and price on those?
Old Feb 6, 2005 | 06:21 PM
kp's Avatar
kp
scroll down a little for a pic
https://ls1tech.com/forums/drag-racing-tech/268942-status-pictures-my-winter-upgrades.html
They were in jegs last time I looked.
edit, guess not in Jegs - I was thinking of lakewood and just noticed Fireball's was a McLoed.
Old Feb 7, 2005 | 06:29 AM
Fireball's Avatar
My installation story
https://ls1tech.com/forums/manual-transmission/258875-mcleod-sfi-bellhousing-installed-pics-info-within.html
Also...It better be enforced. If I'm carrying the extra 30 lbs...then so should every other M6 car
Rules are rules right???
Old Feb 7, 2005 | 04:36 PM
SMOKIN01TA's Avatar
https://ls1tech.com/forums/showthread.php?t=258875
Rules are meant to be broken
but i wont drive that far to find out if i can get away with it.
i think as long as you make weight its all good
Old Feb 7, 2005 | 04:44 PM
Fireball's Avatar
its harder to make weight when you have a 30lb ballast
Old Feb 7, 2005 | 04:50 PM
SMOKIN01TA's Avatar
then you should make minimum weight with no problem
what that thing cost ya and whered ya order it from
Old Feb 7, 2005 | 04:53 PM
Fireball's Avatar
I got it from a local shop who deals with mcleod.
I'm sure thunder can get you one at a decent price
Old Feb 9, 2005 | 09:57 AM
smokinHawk's Avatar
im using a trany blanket, its just the generic fit one, but it fits fine.
Old Feb 9, 2005 | 10:45 AM
Fireball's Avatar
Thats all fine and dandy...but its NOT NHRA OR IHRA LEGAL
Old Mar 6, 2005 | 09:18 AM
redline2k's Avatar
Fireball, do you know the part number of the sfi bellhousing? Because the only Mcleod bellhousing for an ls1 on summit says it is not sfi approved. It is the 8710. Is this a misprint?
Old Mar 6, 2005 | 04:40 PM
Fireball's Avatar
when it originally came out it hadn't been SFI certified yet. The Mcleod 8710 is now SFI certed.
here is a pic of mine
Old Mar 7, 2005 | 07:13 AM
smokinHawk's Avatar
but it helps and is better then nothing
im hoping the ls1tech series wont be to strict about this cause there will be alot of people not racing.
its easy to get on and not that expensive. it will work for me untill i can fit the belhousing into my budget, a cage needs to come first.
