Drag Racing Tech
Autometer Water Temp gauge
Old Feb 8, 2005 | 12:29 PM
The Juggernaut's Avatar
Default Autometer Water Temp gauge
I wanna put one in.
Will the supplied hardware thread directly into the head, or do you need an
adapter?What size is the hole in the head?
Old Feb 8, 2005 | 12:56 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Thunder Racing had to drill my head for this gauge.
Coach
Old Feb 8, 2005 | 01:12 PM
93LS1RX7's Avatar
You dont have to drill the head. Use this adapter this is how I did it with autometer
http://www.egauges.com/vdo_acce.asp?..._Temp_Adapters
you have to get the M12 adapter. Drill out the bottom part of it and it threads right into the passenger side head.
Old Feb 8, 2005 | 01:32 PM
NHRATA01's Avatar
Use the Equus adapter to fit it in the spot at the back of the pass side head. I don't remember the website to buy it from, but if you do a search for Equus you should find it - I'd do it for ya but sorry I'm at work and busy as hell (but not too busy to drop by LS1tech )
Old Feb 8, 2005 | 01:34 PM
Any way to just splice into the wires on the stock unit?
The stock sensor is on the drivers side head,right?
Old Feb 8, 2005 | 01:57 PM
93LS1RX7's Avatar
I dont believe so. Several guys tried and couldnt get it to work.
Old Feb 8, 2005 | 03:31 PM
SilverGhost's Avatar
Motorboater
yes drivers side head, just above and to the left of header primary for cylinder number 1.
Old Feb 8, 2005 | 04:05 PM
JeffT's Avatar
you could do it like this with a manual temp gauge.
Old Mar 27, 2005 | 11:02 PM
TJ's Avatar
TJ
are you reffering to the temp sensor location, or the fact that you can make the autometer work with a factory sensor?
Old Mar 27, 2005 | 11:56 PM
Ryan K's Avatar
Pathological Modifier
Autometer makes the correct adapter. Just screws in, no drilling or tapping. Just tighten it in.
Ryan
