Drag Racing Tech
Car is back from Madman's
Old Aug 15, 2005 | 09:36 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Talking Car is back from Madman's
picked up Project "Censored" today from Madman Racing. Here is what it had done in the last two weeks:
Wolfe 10-point chrome moly cage (certified for 7.50 ET or slower)
cam-lock harnesses installed (both seats)
window net installed
Wolfe thru-floor subframe connectors
Billingsley fab 9" rearend w/ anti-roll bar (35-spline, gun drilled axles)
BMR torque arm, LCA's, panhard
BMR k-member with upper and lower A's
QA1 coil overs
Aerospace front brakes
Strange rear brakes
New brake lines and braided lines
Custom tranny x-member
TCI Dedenbear cased Powerglide installed
TCI torque converter (stalled for 900-1000 rwhp @ 3000 lbs)
TCI Bandit shifter
TCI trans-brake
TCI tranny cooler
Thunder Racing line-lock kit
Billingsley ABS delete block
Madman manual front steering rack
Madman heater delete firewall plate
A/C system completely removed (including inside dash)
catback system removed
Power steering pump removed
airbags removed
ARP lug studs pressed into front hubs
Up next:
408ci iron block to be built by LME
AFR 225 heads
Custom twin-turbo setup to be built by Pro Turbo Kits (twin 60mm)
I'm building the car to run in the Extreme Modified class . Might have it done by the Thunder Racing event in November....
Old Aug 15, 2005 | 09:38 PM
WOT's Avatar
WOT
Sounds like things are coming along nicely. Congrats.
Old Aug 15, 2005 | 09:42 PM
gator's 99TA's Avatar
pics?
Old Aug 15, 2005 | 09:45 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
good to know you're hard at work on another project Tony
Old Aug 15, 2005 | 10:03 PM
Old Aug 15, 2005 | 10:11 PM
MTI Lloyd's Avatar
Tony Car looks great cant wait to see it FLY........
Old Aug 15, 2005 | 10:36 PM
Turo's Avatar
Looks badass. Just curious, why didn't you go with a Madman torque arm (since you seem to be going pretty hardcore with everything else) ?
Old Aug 16, 2005 | 12:21 AM
NA$TY-TA's Avatar
Bad *** Tony...... Shooting for Thunder huh...... When is the car sapposed to go to PTK??? That should take the longest...... What engine management you going with??? BS3?
Good luck
Kyle
Old Aug 16, 2005 | 02:45 AM
al's Avatar
al
Sweet!!!! Looks good.
Old Aug 16, 2005 | 04:30 AM
SPANKY LS1's Avatar
Any pics of the cage straight in through the door?
Car looks great, Shawn
Old Aug 16, 2005 | 08:17 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Turo: suspension components are sponsored by BMR. Its their Extreme-Duty chromoly stuff, not the typical street stuff.
Kyle: I'll be doing the engine before the PTK visit. Maybe a month or two away. Probably going to use BS3
Spanky: Only pics I have. I'll get some more later once I clean up the interior and put new carpet and seats in it.
Old Aug 16, 2005 | 08:24 AM
Turo's Avatar
Ahh, gotcha. Should be badass when it's all done!
Old Aug 16, 2005 | 08:59 AM
93LS1RX7's Avatar
8.50's or slower on the chassis cert. New rule.
Old Aug 16, 2005 | 09:21 AM
MADMAN's Avatar
LS1Tech Sponsor
Wrong it has a 7.50 or slower for the next 3 years. The 8.50 sticker goes into affect in jan. 2006
__________________
www.madmanandcoracing.com
225-343-9029
Old Aug 16, 2005 | 09:43 AM
libertine1015's Avatar
Nice to see a 98 gettin some love since we are the Bastard year
Old Aug 16, 2005 | 10:00 AM
WOT's Avatar
WOT
Once again...looks awesome. But i got a technical Q for you. Why is the caulking poored around the backs of the subframes on the floor. Why aren't they welded in that area?
Old Aug 16, 2005 | 10:10 AM
Dragaholic's Avatar
9 Second Club NA
Tony, what made you go with the front Aerospace brakes over the Strange? I ordered my new rear end with the rear Strange brakes which is what you have, but was curious as to why you went with different fronts.
Old Aug 16, 2005 | 10:27 AM
jasontaws6's Avatar
Looks very Nice. Did you get the rearend narrowed any? What size wheel did you go with and what is the back spacing?
Old Aug 16, 2005 | 11:22 AM
ProjecT 9's Avatar
tony, i must know...what do you do for a living? b/c im gonna seriously look into doing that as well!! nice pics and good luck with the car!
Jon
Old Aug 16, 2005 | 11:29 AM
93LS1RX7's Avatar
Really? SWEET, I thought it went into effect immediately. That is good to know. Thanks Madman.
