Front runner tire or radial tire for skinny
I've run the 165 R15 BF radials for the past several years.
I have no complaints what so ever with them.
I see those "front runner" tires offered by many of the tire manufacture's to compliment like an et street/ et drag or some type of slick tire.
Is there a weight different between a front runner and a radial tire (165 R15)?
I'm thinking yes... but I do not know.
My Weld drag lite 15 X 3.5's with BF goodrich 165 R15's weigh 26 lbs.
I'm trying to shave off every bit of weight and I'm looking into other area's.
Thanks!
If you can tell.... I'm very weight concious... current weight - 2,848 lbs w/o driver
Thanks!
Question, would these be too big?
Mickey Thompson ET Fronts, 27 x 4.5 x 15
Or stick with these:
Mickey Thompson ET Fronts, 26 x 4.5 x 15
Thanks in advance!
Thanks in advance!
what's the deal with this moroso ds2? I've heard most people running, the MT ET front runners. Is this moroso lighter? What is it sacrafising over the MT? ANything?
thanks, I'm about to order my Et fronts and rear's in a day or so.
I run ET Fronts in the 26" variety on my car but like others said they don't last worth a crap on the street. THink I put like 1000 street miles on mine and they look like slicks in the front..
if I hit a puddle i would eat it big time...
The MT ET Fronts are only rated for 3000# max. They are designed for track use, and they are not intended for street. The side walls are weak and will roll over on the rim with agressive turns. They are also very thin and will cut easily also.
Other than that they are a very light tire, but they are expensive. The Moroso DS-2's are basically the same and are cheaper than the ET Fronts by about $30 per tire.
