Drag Racing Tech
Skinnies
Old 11-07-2005, 12:53 AM
code4's Avatar
Default Skinnies
Where can I buy 165R radials on the net? We don't have a pepboys in the area. TIA
Old 11-07-2005, 11:23 PM
SUX2BU's Avatar
pepboys discontinued them. i think tire rack has them. i got mine at my local Firestone.
Old 11-08-2005, 09:51 AM
code4's Avatar
I tried to do a search by size on the tire rack site & came up with nothing. I'll check some local tire places. Thanks for the reply.
Old 11-08-2005, 10:38 PM
NA$TY-TA's Avatar
same here..... i know firestone has them......
Old 12-04-2005, 03:15 AM
code4's Avatar
Found out that M/T makes a radial for a 4" rim. They are spendy but it should be a good tire plus it is 26" diameter. http://www.mickeythompsontires.com/street.html
Old 12-04-2005, 11:48 AM
Retired Street Racer
Matt D's Avatar
Support our sponsors. Tire Rack has them. Kumho power star 758. 165/80/15 I believe the size is. Call the and ask for tires for a VW bug.
EDIT: Here you go:
http://www.tirerack.com/tires/Compar...ark=1&x=8&y=20
Old 12-04-2005, 11:56 AM
kp
kp's Avatar
The Kuhmos are pretty nice tires. The regular 165R has been getting phased out and mostly all you can find is the 'T' version which is a 44psi version with a couple hundred pound more max load for the VW bus.
Old 12-09-2005, 05:42 PM
camaronut502's Avatar
i have 195/xx/15's right now, bought them that way,, they are rubbing in the front when i turn my wheel, will going to a 165r15 help that? thanks
--Matt
Old 12-09-2005, 09:51 PM
chpmnsws6's Avatar
EDIT: Here you go:
thats what i had on my telstars and LOVED em. looked good and they were ULTRA cheap
Old 12-12-2005, 03:16 AM
DesertFox's Avatar
Summit sales them, If you look around you might be able to find the summit discount code for the month. usually about 10% off.
Josh
Old 12-12-2005, 05:09 PM
if my 195/75/r15s i have on my 15x4s are scrubbing when i turn my steering wheel, will going to the kumho power star 758 (165/80/r15) fix the scrubbing problem? thanks
Matt
Old 12-12-2005, 07:45 PM
cablebandit's Avatar
yes...greg has the same tires (as you want to buy) and his dont scrub on the same wheels. he just told me mine scrubbed on his too!!
Old 12-12-2005, 07:47 PM
alright, i was fixing to order them and logical thinking would say yea that would fix it but i jsut wanted to make sure. thanks
--MAtt
Old 12-12-2005, 08:58 PM
chpmnsws6's Avatar
Matt
that will take tire height from 26.52 to 25.39
Old 12-13-2005, 08:49 AM
jerflash's Avatar
yo i called tire rack when i needed mine and they said they had them so i ordered then waited 2 week and nothing...called them back and rhey said we wont have them for 2 months so i went to pep boys like 20 miles away and thay had 4 sets left. i piced up a pair but i ithink i will go back and get the others.
the pep boys tires are rated at a higher wieght and higher psi rating as well...better tire
Old 12-14-2005, 06:10 AM
b1er's Avatar
Jerry's tires did rub on my car....but just barely....left a small mark on my fender liners....
On my wheels...15x5.5 and 15x 8.5 warriors I have a 205/65/15 and 26x10.5 ET Streets.....a bit wider and a touch shorter....don't rub at all...but when I drive to the track on them I do get the ABS and brake lights on after a while (20 miles)....when the slicks are aired down to race pressure(19 psi) the lights stay off....
Old 12-24-2005, 03:45 PM
theoldman's Avatar
Is anyone running 15x4 prostars on a 96 camaro,stock brakes? Do I need to still grind and add spacers?
Old 12-24-2005, 04:08 PM
SUX2BU's Avatar
for the 15x4's you have to grind an INSANE amount AND use spacers.
Old 12-25-2005, 11:36 AM
NA$TY-TA's Avatar
Yep you have to do both.. your better off with a set of 15X3.5's at least with them you can get away with just running a spacer....... but running a spacer isnt legal at the track and really is scary if you think about it.... alot more stress on the studs....
Kyle
Old 12-25-2005, 10:38 PM
VIPRETR2's Avatar
Are you SURE? LT1s have much smaller front brakes than an LS1.
