Drag Racing Tech
What to do to prevent from engine losing oil do to wheelies?
Old Nov 21, 2005 | 07:26 PM
Dragaholic's Avatar
9 Second Club NA
Default What to do to prevent from engine losing oil do to wheelies?
Wheelies aren't new to LS1 F-bodies, so what has/is being done to prevent engine from losing oil while wheeling and toasting the engine? I certainly don't want this to happen to whatever I build next. Thanks in advance.
Old Nov 21, 2005 | 07:32 PM
FANTAZ28's Avatar
Moderator
canton oil pan!!!
Old Nov 21, 2005 | 07:36 PM
Dragaholic's Avatar
9 Second Club NA
What's different about the Canton over the stock that prevents the engine from going dry?
Old Nov 21, 2005 | 08:13 PM
FANTAZ28's Avatar
Moderator
i belive they have baffling to prevent the oil from going back ..
what was madmans advice?
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Maybe, listen to Madmans advise next time!
Coach
Old Nov 21, 2005 | 08:29 PM
Dragaholic's Avatar
9 Second Club NA
What advice? Is there a post I'm missing?
Old Nov 21, 2005 | 08:51 PM
Zippinzee's Avatar
An accusump would help. I believe they are made by moroso. Sorry they are made by canton.
Old Nov 21, 2005 | 08:55 PM
Zippinzee's Avatar
An accusump would help. I believe they are made by canton
Old Nov 21, 2005 | 09:07 PM
gator's 99TA's Avatar
dont do big wheelies dummy!
suspension limitors and less bite
Old Nov 21, 2005 | 09:20 PM
Dragaholic's Avatar
9 Second Club NA
Whoa, no need for name callin'. I have travel limiters in the front. I limited the travel by 2 inches. The pass after the bumper stand, I tighten the shocks from 0 to 3 and it help keep it down and I cut the best 60 ft., 1.36!!!
Old Nov 21, 2005 | 09:30 PM
Ben R's Avatar
Instead of limiting the front-end travel by 2", you should have limited the travel to 2" total.
Just get a dry-sump. It's worth 30HP anyways.
Old Nov 21, 2005 | 10:21 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Some places modify the oil pickup in the pan.
Old Nov 22, 2005 | 09:41 AM
Carbed4thGen's Avatar
Wat? I'm guessing this was a joke right?
Old Nov 22, 2005 | 11:14 AM
Maggie's Avatar
The internal configuration supposedly helps prevent acceleration starvation and starvation due to foaming...
Like Pro Stock John said.
You can have the oil pic up modified.
Another alternative is a pressurized auxiliary reservoir.
Old Nov 22, 2005 | 02:15 PM
TApimp's Avatar
I think the canton pans have a hinged trap door
Old Nov 22, 2005 | 03:04 PM
Ben R's Avatar
Dry Sump = power.
Old Nov 22, 2005 | 03:06 PM
BKHAWK1's Avatar
Either way you are looking at spending $$$. moding the pick up is proabaly the cheapiest fix.
Side note: do you have any pics of the wheel stand?
Old Nov 22, 2005 | 06:53 PM
Noyzee's Avatar
8 second mod
a dry sump is big $$$$$$ nice, but big $$$$
Old Nov 22, 2005 | 08:29 PM
Dragaholic's Avatar
9 Second Club NA
Does anyone know who modifies the stock pan or is this something that can be done at home? My father and I have pretty good fabrication skills, so I'm sure we can do it ourselves, but would need to know what needed to be done?
Old Dec 2, 2005 | 01:18 PM
Dragaholic's Avatar
9 Second Club NA
We finally got around to taking the motor out and completely tearing it apart. It wasn't bad at all and did it all within the day. Anyhow, oil starvation was the problem. So is modifying the stock pan a pretty common thing? If so, does anyone have pics? I'm tempted to buy the Canton oil pan, but is $500 and wanna be sure that I'm not wasting my money when I can modify my own and be safe.
