Drag Racing Tech
subframe connectors help ?
Old Nov 23, 2005 | 06:53 AM
oOoLy's Avatar
Default subframe connectors help ?
I must use the subframe connectors for drag racing or not ? It will help me in the drag racing ?
Old Nov 23, 2005 | 08:46 AM
NO CATZZ's Avatar
They are not required for drag racing but they do help stiffen the car which makes the suspension do all the work instead of the body twisting and flexing. If you race a lot you can eventually end up with misaligned doors and T-Tops. They will help with drag racing because they eliminate body flex which allows you to tune your suspension more predictably.
Old Nov 23, 2005 | 09:01 AM
jerflash's Avatar
and they will have gaurd against those nasty ripples we get on the quater panals fomr hard launches at the strip
Old Nov 23, 2005 | 06:57 PM
Matt D's Avatar
Retired Street Racer
Just get a roll cage. If you are drag racing, you are eventually gonna need one. It will stiffen the car up, and save your *** if you run into trouble.
Old Nov 24, 2005 | 06:15 AM
oOoLy's Avatar
What is the best roll cage ?
Old Nov 24, 2005 | 08:01 AM
Steve Burger's Avatar
LS1TECH Sponsor
Do both.
Old Nov 24, 2005 | 08:17 AM
davered00ss's Avatar
Moderator
Wolf is the most popular roll cage. Get the SFC's. They will save you from doing body damage to your car.
Old Nov 24, 2005 | 08:16 PM
Matt D's Avatar
10 point chrome moly cage from Alston
