Drag Racing Tech
mach 1 question...how fast???
Old Dec 9, 2005 | 12:59 PM
Casey98Z's Avatar
Default mach 1 question...how fast???
ok i have a 98 Z and my friend/ sisters bf has a 03 mach 1, beautiful car, feels fast going thru the gears...i do really like this car, but my sister seems to think he can hang with me, or for that matter beat me, currently the car runs 13.61 and consistent 13.7s, well before headers, catted y and converter.......are these mach 1's that fast, everything i see on them is in the 13.8-14.1 range at BESt!!,and seen one at atco pull a 14.30, so, what do these cars run bone stock!!!
Old Dec 9, 2005 | 01:09 PM
Bitemark46's Avatar
With the 5 spds I say the average Joe can pull 13.5-13.6's stock. I think the fastest stock time was 13.1X
They do come in auto and I'd say higher 13's maybe low 14's for those. Could be a drivers race when you run him. Good luck. -Mark
Old Dec 9, 2005 | 01:44 PM
NOZR1's Avatar
They are definitely no slouch. I have seen many run low to mid 13's stock.
Old Dec 12, 2005 | 03:20 AM
DesertFox's Avatar
Mach 1's are ls1 fast. However they make their power in the 1st 500-660 feet. The ls1 should own it on the top end, stay in it and you could pull it out in the last half.
I have a friend with an 03 mach 1, 5 spd. He has 4.11', axles, x pipe, cat back, and a 75 shot. On ET Drags, he runs 12.5 ish on spray, and low 13's motor. and his 60' is consistently below 1.8 ( that is the upper range of his 60' times).
They are fast fords, be careful.
Josh
Old Dec 12, 2005 | 04:08 AM
1 BLOWN V8's Avatar
A friend of mine has a 03 5 speed with a K&N cold air kit, X-pipe with catback exaust. His best run to date is 8.9 1/8 and 13.9 1/4 so far. He is not that bad of a driver either.
Old Dec 12, 2005 | 05:42 AM
Z2K_MrJ's Avatar
Board Certified Idiot
They can be nasty with a good driver.. on the street tho stock for stock the ls1 has it
Old Dec 13, 2005 | 09:41 PM
Silvrshark's Avatar
No disrespect but evidently He don't know how to drive.
Old Dec 13, 2005 | 10:04 PM
camaronut502's Avatar
thiers a supercharged mach1 running around down here and hes been beat by two different t/a's both on motor 1 a auto and the other a m6.. i wanst to impressed.
--Matt
Old Dec 13, 2005 | 10:05 PM
1 BLOWN V8's Avatar
I would have to agree with you but I have seen 3 other Mach 1's also run about the same times as he does. I do think the 60 foot has some to do with it also.
Infact i watched 2 03-04 cobras run last weekened at the 1/8 track and one ran a best of 8.3 and the other was a 8.4
Both had pulleys and other work also.
Old Dec 15, 2005 | 10:14 AM
AL SS590 M6's Avatar
My wife bought an 04 Mach1 auto trans car. We took it to a charity drag race event in the cold October Michigan weather. It ran 13.74 at almost 101 mph totally stone stock. But remember this was a very good air day.
Old Dec 15, 2005 | 11:28 AM
Casey98Z's Avatar
thanks guys for all the info so far
Old Dec 21, 2005 | 07:55 AM
CompMach04's Avatar
--Matt
I doubt that it would lose too an all motored ls1 unless it had head work or cams or nitrous. Supercharged Machs put down anywhere from 440-460rwhp with 8psi and low 11 sec times and Desert Fox was right they are about even, stock giving the adavntage to the ls1 with the mach faster or even down low and the ls1 faster up top.
Old Dec 21, 2005 | 08:33 AM
1 BLOWN V8's Avatar
What does a stock mach 1 put down from the factory? I could of sworn I have heard anywhere from 280-300. So a supercharger at 8 psi is going to give them a extra 140-160 to the wheels?
I know my 03 Cobra with a cat back, kb cold air kit, accufab throttle body, a 2.93 pulley at about 12psi and a full tune put down 438 to the ground.
I dont see a mach 1 putting down 440-460 on just a supercharger at 8psi.
Maybe I am wrong here.
Old Dec 21, 2005 | 08:41 AM
Bitemark46's Avatar
I think he may be a little generous with those #'s. But I would say around 420. Remember the blower is not a roots type it's a centri blower so peak #'s will be higher but won't put down the tq compared to your car. I also think that your basic blower kit will either come with a 8# or 10# pulley. But 140-160rwhp is not uncommon when slapping on a centri on these 4v's. -Mark
Old Dec 21, 2005 | 10:25 AM
1 BLOWN V8's Avatar
That could be true. I forgot to add the torq. Mine was 463 to the wheels.
Old Dec 21, 2005 | 10:43 AM
Bitemark46's Avatar
Ya you'd definately have more low end. Typically centri blowers with stock pullies will have 370-400rwhp. Also under the curve you'd would have alot more power. If both cars put down the same peak #'s but say 3500rpms you'd may have 50-80rwhp on him. -Mark
Old Dec 21, 2005 | 11:10 AM
well i know for sure one of the ls1 cars has a cam and bolt ons, the mach1 had some 4.30 gears and dynod 435, and got out ran from a stop and a roll. the other car was spraying a 100 shot (i went back and found his post, my bad). im just that imoresed with htem.
--MAtt
Old Dec 23, 2005 | 08:20 PM
San Pedro Mach's Avatar
Like it's been said...
Machs are nasty, especially from a dig. They are set up to pull hard of the line, but LS1s have a better top-end so the longer the race is the better for the LS1.
Stock times are anywhere in the mid/low 13s...depending on the driver.
