Drag Racing Tech
front swaybar removal??
Old Mar 6, 2006 | 08:48 PM
ss1129's Avatar
Default front swaybar removal??
How does having the front swaybar removed help the 60'? I searched my fingers off trying to find this?
Old Mar 6, 2006 | 08:59 PM
ninetres's Avatar
better weight transfer to the rear = better traction = better 60 ft. time
Old Mar 6, 2006 | 09:02 PM
98 Raptor TA's Avatar
i also always wondered how much it helped to remove the sway bar, i'm sure it helps, i just kinda wonder the actual amount of change it makes to your 60'
Old Mar 7, 2006 | 03:18 PM
chrs1313's Avatar
Do a controlled experiment at the track, 3 passes with it on and 3 with it off, if you can get more than 6 passes then do that.
Old Mar 7, 2006 | 05:45 PM
Little G's Avatar
I never noticed a change in my 60s, I just did it for weight reduction.
g
Old Mar 7, 2006 | 06:24 PM
WILWAXU's Avatar
Better weight transfer and less weight.
Old Mar 7, 2006 | 06:52 PM
zspot98's Avatar
Well I just did this actual experiment last week. 3 passes w/ the sway bar on. All 3 were either 1.9 or 1.8 60' times. Took the sway bar off and then made 3 passes all were 1.6 60' times. 2 to 3 tenths on the bottom isn't too bad IMO. I went from 7.8's to 7.5's in the 1/8. Well worth the 15 minutes it took me to take it off IMHO.
Old Mar 8, 2006 | 10:04 AM
chrs1313's Avatar
wow that is a huge difference i didn't think it was that much, nice to see
Old Mar 8, 2006 | 10:23 AM
BURN'EM's Avatar
I've seen as much as 2.3 dropp from removal, however my average out of the runs was 1.95. But for track use take it out, your not making turns.
Old Mar 8, 2006 | 03:25 PM
monsterls1's Avatar
I took mine out just for the weight savings, but i did too many things to the car at the same time to know how much of a difference it made, but any weight savings is a good thing!
