Drag Racing Tech
Cutting radiator support
Old Mar 31, 2006 | 11:42 PM
foggedz's Avatar
Default Cutting radiator support
Does anyone have any pics before and after cutting out extra material from the radiator support.
Old Apr 4, 2006 | 01:11 PM
Thunder175's Avatar
I will here in a while... the lower core support is being replaced with chormoly for a new radiator.
Old Apr 4, 2006 | 03:38 PM
Pavlock Performance's Avatar
i cut mine but dont have any pics. it turned out really good and it picked up at the track.
Old Apr 4, 2006 | 06:46 PM
DopeFedZ's Avatar
Here is mine cut out. Once I get my radiator I'll fab up something to hold it in.
Old Apr 4, 2006 | 11:28 PM
ls1408cp's Avatar
now thats hardcore
Old Apr 5, 2006 | 12:01 PM
jshiver's Avatar
WOW>>>that is EXTREME....I was just thinking about cutting out the cross-bar and then fixing a way to bolt it back in...making engine changes alittle easier...Has anybody else done this..(but not to the extreme...above)?
Old Apr 5, 2006 | 12:07 PM
coop5885's Avatar
here is a quick after
we cut it and then boxed it and welded in a piece of angle to mount the radiator to.
Old Apr 5, 2006 | 01:45 PM
fitz98ta's Avatar
so when you gonna paint that Coop?
Old Apr 5, 2006 | 01:48 PM
Navy David SS's Avatar
Here's mine
David
Old Apr 5, 2006 | 03:00 PM
Outlaw's Avatar
Here is mine...
This is with it bolted in.
And with it unbolted
And the center sitting on the ground
Old Apr 5, 2006 | 03:08 PM
DopeFedZ's Avatar
I want to end up with something like Navy David has set up.
Old Apr 5, 2006 | 05:54 PM
foggedz's Avatar
Awesome thanks. I was thinking about just cuting out the lower section, and then bolting in a piece of aluminum to run along the bottom of the radiator to hold it in.
The only other question I had was about the hood latch bracket. part of the bracket attaches to the lower radiater support. If I cut out the lower support the latch bracket will only mounted to 2 points. Will the hood still open and close correctly?
Old Apr 5, 2006 | 06:08 PM
JPMuscle's Avatar
You shouldnt have a problem with the lower mounting bolt, Mine broke awhile back so only the two points were holding it in and it was fine.
Old Apr 5, 2006 | 06:43 PM
yeah mine was extremilly conservative unlike these guys.. i drive my daily
Old Apr 5, 2006 | 07:28 PM
jshiver's Avatar
Outlaw...would you mind sending me those pics to my e-mail? it is jshiver101@comcast.net
I can only see red x's on here...Thanks,Jason
Old Apr 5, 2006 | 08:20 PM
SUX2BU's Avatar
Here a crappy pic of mine. i'll try to get better pics soon. i only did this for weight savings and nothing else.
Old Apr 5, 2006 | 10:32 PM
Outlaw's Avatar
My site was off line for some update.. should be ok now
