Homemade!! LOL
thats why I cut out the front grill area and did the big gulp mod
http://img.photobucket.com/albums/v3...Picture721.jpg
They aren't in front of the radiator? You ever look at a stock F body? Theres a plastic shroud covering the whole radiator, so the airdam can push air up into the radiator.
, so you get the maximum air into the engine, make it a sealed box, use some weather stripping, how in the intake box going to see the small but still there 0.25psi when you are a tthe traps with the air box not sealed, https://ls1tech.com/forums/attachmen...chmentid=58494
Chris
From what i remember its 16"x8" two 4" holes, i belive the holes are each 1.5" from the front and each 3" from the edges.
Oh and from underneath the "lip" on the holes is 1.25" deep.
I think it is a great mod if you pick up HP at 90+ mph!! That could easily cot off a tenth or 2, and tack on a few extra MPH. Not only the "ram" effect at HIGH speeds, but you can not argue against the fact that it pulls in cold air
