need help ASAP on tires!!!!!!!!!!!!
1. # of Plys on the sidewall.
I actually used to run Kumho's 165/15 metric tire. It was cheap but it was only a 4 ply sidewall tire. Meaning even when I put the max air pressure it still looked low. Now if I had a gutted foxbody (sub 3000lbs) then I probably would of been ok. But anything over 3000lbs I'd opt for a 8 ply sidewall. I searched but it didn't say how many ply's it was. But it does say for small sports cars so it may be only 4.
2. Speedrating
My old tires as with the one in your link have a speed rating of "T". Meaning they are rated up to 118mph. Now I'm sure you'll be ok just for 1/4 mile blasts but I'm sure if it's not your main tire/rim combo it will probably outlast your power level and I'm sure you'll surpass that mph before you know it.
I wouldn't cut corners with tires. 3.5 rim is very skinny rim. For the strip it's fine but if you drive on the street especially when turn you're putting alot of load on the studs. A buddy of mine had a 95 mustang with a iron blocked 397. It probably weight 3700lbs and he turned a corner and when it straightened the rim (3.5" Weld draglight) broke all around the studs. Just be careful.
This is what you should get:
http://store.summitracing.com/partde...5&autoview=sku
-Mark
Yeah, we go out to North Ave & 83, 75th & Lemont, and Harlem and 159th. Those are the usual spots we meet up at unless we do like a Hooter's meet. Check out the midwestern forum. we usually post up where we are going.
I drive 90+ miles a day on my 165R15's (the 44 psi ones) drive it like a regular car, taking corners at avg speed and everything.
Being cheap is cool, till it affects your safety.
