Drag Racing Tech
Drag wheels weights
Old Apr 21, 2006 | 03:00 PM
LSs1Power's Avatar
Default Drag wheels weights
This thread is just to gather information about Drag wheels weights only. Not stock wheels with drag tires. So please if you had ever weighted your drag wheels either skinnies or rear wheels list them below:
1. Wheel brand (ex. Bogarts)
2. Wheel name/type (ex. Dragstar) Or (ex. Fluted Star Fronts, Dragstar rears)
3. Front wheel size and weight (ex. 15x3.5, 8lbs)
4. Rear wheel size and weight (ex. 15x10, 10lbs)
If you are running different type of wheels in the front or the back please say so. Same thing goes to running different brands in the front and rear.
Thank you.
Old Apr 21, 2006 | 03:19 PM
Mike Comp T/A #57's Avatar
Bogart D-10
15 x 4 front 9 lbs
15 x 10 rear 11 lbs
Old Apr 21, 2006 | 07:02 PM
ls1 joe's Avatar
Anyone know the weight of draglites 15 x 10s
and 15x 3.5
Old Apr 21, 2006 | 10:05 PM
00SS4780's Avatar
All the weights are with tires.
front/ prostar 15x3.5 w/165metric =========25
rear/ prostar 15x8 w/26/11.5 et street ====35
rear/ prostar 15x8 w/275/50/15 drag radial =45
Old Apr 22, 2006 | 09:00 AM
JNorris's Avatar
Moderator
This post has a lot of wheel weights with some drag wheel weights in the mix as well.
https://ls1tech.com/forums/wheels-tires/471204-common-wheel-weights.html
John
Old Apr 22, 2006 | 09:02 AM
LSs1Power's Avatar
https://ls1tech.com/forums/showthread.php?t=471204
John
I did check that thread before when i searched. The idea of this thread is just drag wheels weights and not a mix of wheels.
Old May 5, 2006 | 10:06 AM
chrs1313's Avatar
bump interested to know the weight of convos15 x 3.5 and 15 x 9.5
Old May 5, 2006 | 09:25 PM
Tally TransAm's Avatar
holeshot holestars
fronts = 7#'s
rears = 9-10#'s
Old May 5, 2006 | 10:12 PM
NRC-Motorsports's Avatar
what kind of drag radials? I had 15x8 prostars on my supra with 275/60/15 m&h drag radials and they weighed 41lbs.. my father has a set or 315 mt radials on his buick with steel wheels and god help him those things are 80lbs each
jay
Old May 5, 2006 | 10:28 PM
LSs1Power's Avatar
Originally Posted by Tally TransAm
holeshot holestars
fronts = 7#'s
rears = 9-10#'s
Size?
Old May 6, 2006 | 05:32 AM
15x4
15x8
10's are 1# more for the rears
Old May 6, 2006 | 05:56 AM
1_Bad_LS1's Avatar
Weld Pro Magnum's
15x3.5 - 7 lbs
Rear to come
Old May 6, 2006 | 10:22 AM
SScam68's Avatar
1. Welded Bogart
2. P1 D10
3.
15x3.5, 9lbs
15x9.75, 10lbs
Tire weights (no rim)
Moroso DS-2 11lbs
26x10.5x15 ET Street - add rear tire weights in a bit.
FWIW as a comparo on the same scale 26x11.5x16ETstreet + stock 16 camaro rim 38lbs.
I wonder what the P2's weight in at.
Old Jun 16, 2006 | 10:20 PM
oztrack's Avatar
What is the weight of Bogart race wheels and MT ET Street Radials with 235/60 x 15
also the bogart fronts and light radial tyres??
My stock steel wheels and tyres and 37lb each for fronts and 44lb backs.
Old Jun 16, 2006 | 10:52 PM
SJM Manufacturing Inc's Avatar
Remember guys, our Bogart wheels will vary in weight according to how we build them for the application. So you may see different weights listed due to different built setups.
When you guys are weighing wheels (other brands)..ADD the spacer and whatever else you added in with the weight of the wheel. With our wheels, when we build them, the weights are listed as an assembly for an LS1 for example, we use custom centers, added welded material on the inner centers etc...after all is said and done, we are still much lighter then a prostar for example.
Some state that our wheels are "not that much lighter", consider this, a 10" prostar is only ~ 6-7lbs lighter then a stock wheel. Our LS1 setups are typically 5lbs lighter then a prostar. Not to mention with a prostar, you need longer studs and longer lugs which all add up.
We really are looking at different setups though...a more fair comparison is to the weld alumastars 2's which are very nice wheels...they are part of welds high-end wheel setups.
We can build a front runner down to ~6.75 lbs...when we build them for different setups, weight varies according to what we are doing to the wheel.
Old Jun 17, 2006 | 08:15 PM
Damage Inc.'s Avatar
Sweet Cheeks
Exactly.
I love my P2 Aluma Lites.
Bogart Aluma Lites
Front: 15x3.5 - 6.75lbs
Rear: 15x9.75 - 9lbs
Thanks again Steve.
Old Jun 17, 2006 | 08:21 PM
skipperbisket's Avatar
pics of the aluma lites?
Old Jun 17, 2006 | 10:21 PM
SScam68's Avatar
Drag brakes are required right?
For P2 wheels?
Old Jun 19, 2006 | 11:17 AM
Sweet Cheeks
For P2 wheels?
Yes, drag brakes are required.
Pics will be up within the next few weeks.
I'm waiting on getting the rearend narrowed.
