Rollcage advice needed
I really had in my head that I wanted the bars....BUT..I also don't want to make a big mistake...Help me make a decision
Here is a shot from when i was doing some wirring
You are making me think in the morning.. bad bad bad.. ok so after thinking about it.. here is my dead
Right leg in the car and then i back my *** into the car while holding onto the cage i lower myself into the seat.
If you are not going 25.5, you can do the other X bar lower so that you can get in and out over it far easier. In Dave's picture, if you brought that bar down about 4" you would have less of an issue getting in and out. That and a removable steering wheel would help out a bit.
As for the new setup we moved my seat back another 8" which opened up the X quite a bit to get in and out of. You won't have that choice on a regular setup. It physically looks the same as Dave's but gives me a running start at the door as far as legroom goes.
At this point the firewall is almost done up. I just have the lower half to do and a little more of the floor. After that I'll get the car stripped and we'll prime it. You can see more of the photos here: http://www.stenodracing.com/gallery/...s.php?album=21 I need to get some more photos of the car posted up as I go along with it.
David
