Drag Racing Tech
slicks and transbrake obsolete?
Old May 18, 2006 | 10:44 PM
gator's 99TA's Avatar
Default slicks and transbrake obsolete?
with the way guys in our cars are launching the m/t drag radials on a footbrake (1.35-1.40 60' are getting to be more common with some folks here), is a trans brake launch on slicks even worth it anymore?
is there a need for bias ply tires and shocking the driveline ( talking cars looking for 1.3 60' and slower)? here is one of our local "girl" ls1 4L60e racers getting it done on the 28" radials.
http://www.drivelinestudios.com/nbna...alsweb1024.jpg
just wondering what you all thought.
Old May 18, 2006 | 10:50 PM
skipperbisket's Avatar
i was thinking about this a while back myself. with guys like Wolfe going 7.50s on drag radials, is there really any reason any of us in the 9-12 second range should need a full big *** slick. i mean if they can hook up those cars and run those numbers on a street tire, there is no reason a 9-12 second car should need any more tire than that. hell, even on his 7.5x passes on drag radials Wolfe was still going 5.1x 1/8th miles so its still getting out there pretty hard. i'm setting my car up to run radials and/or a 28x10.5" slick depending on what class it ends up in here locally.
Old May 18, 2006 | 11:05 PM
well i dont want to compare the 7 second radial tire cars b/c they are running a 30" 315 drag radial. lets keep the discussion to 9 second and slower cars. basically the vast majority of drag cars on this board running a 28" tire.
Old May 18, 2006 | 11:07 PM
i was just using that as an example, basically if a 7.5 second car can get it done on a radial, i see no reason that an 8-12 second car can't do the same.
Old May 18, 2006 | 11:10 PM
it just seems so much more simple. no trans brake. no 2 step. no anything. just put in 20 psi in the tires and footbrake it. bam, 1.3-1.4 60' times.
Old May 18, 2006 | 11:16 PM
i could see that a 2 step would be advantagious due to the same RPM launch consistancy, making it easier to dial in the suspension etc would be good. when i run on radials i intend on footbraking to whatever rpm and gettin it done. on slicks thats a different story.
Old May 18, 2006 | 11:19 PM
ok, so definately reaction time is an advantage along with consistency. but to me it also seems like a slick/TB is more things that could go wrong (over complicating things). again talking 9-12 second cars here.
Old May 18, 2006 | 11:22 PM
Ben R's Avatar
Cars with DR's need to hit the tire harder than cars with slicks. DR's are certainly not superior to slicks. Most people with LS1 cars have super craptastic off the shelf converters that are super in-effecient and not what their car needs.
Old May 18, 2006 | 11:25 PM
badass 2002 z28's Avatar
My car leaves better off a footbrake than a trans brake. It 60fts about the same with both, but overall the suspension works better footbraking.
Old May 18, 2006 | 11:27 PM
you dont mean "shock" the tires harder with radials right? do you mean cars with radials to run the same number must put more power to the ground? i am confused.
what does converter efficiency have to do with hwo well the car launches on slicks versus DRs?
Old May 18, 2006 | 11:28 PM
i remember joe overton saying the same thing about his car as well.
Old May 18, 2006 | 11:54 PM
Ben R's Avatar
Running DR's is a complicated mix. They're a lot less forgiving than slicks are. If I built a DR car it would definately hit the tires hard. The hard part is keeping them planted.
Converter effeciency is a trate of the crappy converters I was trying to describe. It really have TOO much bearing on how a car launches, but it does matter. Speaking of converter effeciency I have a racepak graph from a Nostalgia Pro Street racer who saw 1:1 through the lights. Pretty neat stuff.
Old May 19, 2006 | 12:10 AM
LC's Avatar
LC
So, a Drag Radial will hook as fine as a Slick if the Suspension is prepared to.
a Slick would hook on "any" suspension setup...
Kinda like that?
325/50/15s vs Stiff Slicks... ( slicks are cheaper! )
Old May 19, 2006 | 07:36 AM
MADMAN's Avatar
LS1Tech Sponsor
Joe O was scared of his trans brake.
I agree with Ben. With a drag radial you need to shock the tire. The harder the shock the better the hook if you can control it. If you set the car up correctly a trans brake will out launch a footbrake car.
__________________
www.madmanandcoracing.com
225-343-9029
Old May 19, 2006 | 07:38 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
This statement is my car to a T.
Coach
Old May 19, 2006 | 08:29 AM
Carbed4thGen's Avatar
The difference here is the guys runnin these 7.5's on a DR are making HUGE power and are in a "controlled" spin most of the time
Old May 19, 2006 | 08:57 AM
Matt D's Avatar
Retired Street Racer
I do not use a transbrake or 2 step, but I do use a proportioning valve so I can foot brake my 4600 converter higher with the MT drag radials. You might want to look into one of those John.
Old May 19, 2006 | 09:29 AM
Coach
coach you dont run a transbrake? that really surprises me with you into braket racing so much. esp with how much madman pushes the tb. i figured the footbrake woudl slow your r/t
Old May 19, 2006 | 09:51 AM
MADMAN's Avatar
LS1Tech Sponsor
Coach runs a No Electronics class. So we cant have a trans brake. He does have worse reaction times on a .400 pro tree on the foot brake.
__________________
225-343-9029
Old May 19, 2006 | 09:59 AM
Loudmouth LS1's Avatar
If I remember correctly, he runs the footbrake class, that's why no tbrake. If you run a tbrake, you have to run with the guys with all sorts of electronics like delay boxes and all that **** and it makes it a lot harder to win.
