Drag Racing Tech
help with suspension setup
Old May 27, 2006 | 07:46 PM
yak's Avatar
yak
Default help with suspension setup
I am currently trying to get my car to hook
right now it makes about 385rwhp cam only.
4k stall, 3.42 gear, car spins through first and second on warm drag radials.
I would like to get the competition 3 way adjustable shocks for the rear and kep the stock springs there. in the front I want the qa1 shocks but am unsure of the springs. can anyone help me out here? also is there anything I am missing to make me car hook like a ****?
Old May 27, 2006 | 08:19 PM
Wyoming T/A's Avatar
a little softer spring will let it transfer more
Old May 27, 2006 | 08:39 PM
1999TransamWs6's Avatar
put a softer spring in the rear and some stiffer springs up front like some 60/40's or 90/10's. With your power 90/10's would be nice. I have the AJE front suspension set-up (pics in sig) and my car dead hooks at 667RWHP on a stock rear and stock rear suspension. Its all about getting the weight out of the front and in the back or just gone for that matter. Hope this helps a bit......QA1 is a nice piece for the money my front set-up was a bit on the pricey side but I dropped over 7 tenths when I changed just the front set-up.
EDIT: You get what you pay for. Good luck
Old May 27, 2006 | 08:52 PM
THE LAST Z's Avatar
Torque arm set at -2 pinion angle
LCA's & panhard
LCA relocation brackets
Old May 28, 2006 | 06:16 AM
JL ws-6's Avatar
Race your car!
leave the stock springs on the front and back, just get a set of qa1 shocks for the car... the gains will be well worth it.
Old May 28, 2006 | 09:35 AM
JMBLOWNWS6's Avatar
I use the 300# QA1 springs in the front and leave the back alone. With the 12 way adjustable QA1's all the way around. Fill in the rear with tire The Hammer mod works well and the fenders rolled.
Old Jun 7, 2006 | 03:02 PM
madmatt97's Avatar
vinny it was more like 185wrph i saw the video.
Old Jun 7, 2006 | 05:10 PM
tektrans's Avatar
Which drag radials? size? Torque arm?
I would say with a "good" set of drag radials, torque arm, tubular or boxed lower control arms, Hals and maybe an airbag you'll hook no problem.
Old Jun 7, 2006 | 05:18 PM
yak's Avatar
yak
yeah I really need a torque arm I am still on the stock one
oh and matt, at least I have a motor in my car now...
