Drag Racing Tech
AC box removal
Old 06-03-2006, 03:49 PM
Badmire68's Avatar
Default AC box removal
Any tips on removing the AC box? I'm wanting to get rid of it but still keep the heater core in place. Does anyone make a plate to do this?
Old 06-03-2006, 07:48 PM
tektrans's Avatar
It's kinda all one unit I think. I removed everything. The heater core is kinda "in" the box.
Old 06-03-2006, 09:09 PM
Shon Herron's Avatar
Check out FRRAX for this mod, pretty cool how one dude cut out some stuff to get the weight out but he has heat.
MOST that want to keep heat will just end up removing under hood equipment and keep the interior stuff b/c it is all one (fan motor etc....)
Old 06-03-2006, 09:29 PM
Badmire68's Avatar
thats exactly what I want to do Shon. thanks.
Old 06-04-2006, 10:39 AM
phoenix's Avatar
whats FRRAX? some ones user name?
Old 06-04-2006, 11:06 AM
blue01ta's Avatar
F-body road racing and autocross forums.
www.frrax.com
Old 06-04-2006, 11:56 AM
phoenix's Avatar
thank you
Old 06-05-2006, 02:27 PM
John_D.'s Avatar
It's a job... Might be easier to just go with an aftermarket heater. Look for my user name over there and the term hvac. You'll find the post about it.
After you get through the notes and the pics, give me a holler if you have more questions...
Old 06-05-2006, 03:02 PM
11SECSS's Avatar
This is what I did to mine:
Old 06-05-2006, 03:05 PM
11SECSS's Avatar
here it is out of the car...preparing for mock up.
Old 06-05-2006, 03:12 PM
daniel6718's Avatar
easy with the motor out huh?
Old 06-05-2006, 08:16 PM
Badmire68's Avatar
11sec SS, so that is just the stock box cut with a peice of sheet aluminum/metal mounted to the front?
Old 06-05-2006, 08:19 PM
Badmire68's Avatar
I'll check it out. BTW I see your from Lebanon. I'm originally from Mt. Juliet. thanks for the info and help.
Old 06-06-2006, 08:52 AM
11SECSS's Avatar
yes ,I cut part of the front to allow the air from the fan to travel thru some where someone has cut theres flush but had to modify the inside .The way I did mine looks good and has plenty of room to get to the rear plugs easy.
Old 06-06-2006, 05:33 PM
Badmire68's Avatar
it looks really good. when I get this thing out I'm going to try to make it look like yours.
Old 06-06-2006, 08:04 PM
Race your car!
JL ws-6's Avatar
I am gonna try somethign a little differnet, not sure it if will work out... but what I plan to do is get a small radiator/tranny cooler, something like that,and run the hoses from the water pump to it. I lan tomount it somehow inside inder the dash, and attach a small fan or 2 to pull air off it, or blow air thru it thru the vent hole in the center of the transam dash at the windshield... it's pretty much so I have a defroster for those cool damp nights that I take my car out to a car show so the windshield doesn't fog up. I plan to make a shorud out of foam or some type of plastic so the air is forced thru the dash vent.
I'll post up pic's and how it works out after I get it done.
