Drag Racing Tech
Wheelie Bars
Old Jun 10, 2006 | 09:52 AM
ApacheDrill's Avatar
Default Wheelie Bars
For those of your running them, what brand are you running and how much goes into this.. Are they just bolt on?
Old Jun 10, 2006 | 10:46 AM
DERTY's Avatar
The Bull
Some fabrication required. Most people just get them done up by a local chassis shop. The fun part is making it all fit while keeping the T-top well.
You could attempt to buy a generic kit from a chassis shop and make them fit. But you'll have to put the brackets on your housing which is going to take a little welding. That's provided that you can get them to fit around your panhard bar without relocating it. Some stock suspension classes have a problem with altering the location of the panhard while others do not. That's something you need to double check on first.
Old Jun 10, 2006 | 01:17 PM
skipperbisket's Avatar
i'm putting the Wolfe setup on my car, i plan to cut the ttop well out and move it up some anyways and make a box for the battery etc.
Old Jun 10, 2006 | 08:07 PM
Navy David SS's Avatar
Bought mine from Jegs. Generic. Like said, a lot of modifications to the car. T-top holder area, gone. Didn't have to relocate pan-hard. I was moving the battery to rear anyway, and putting fuel and water cells in also.
Here's pictures of the wheelie bars and "new" trunk area.
David
Old Jun 10, 2006 | 09:13 PM
Well looks like that alot more then i expected.. I has planning to tub it down the road, guess ill wait till then when everything is torn apart..
Old Jun 10, 2006 | 10:05 PM
check out the wolfe wheelie bar setup, probably a more "bolton" type deal (with welding instead ofcourse though)
Old Jun 11, 2006 | 08:45 PM
i didn't mean "bolton" bars, what i meant by that was that they are built specifically for the fbodies and are a direct install, no fab work involved.
Old Jun 12, 2006 | 09:17 AM
Carbed4thGen's Avatar
David
Hey David what did you do as far as a rear bulkhead for the car? Any pics?
Old Jun 13, 2006 | 11:37 AM
Big Rick's Avatar
I've got Jerry Bickel Pro Mod Bars built by Madman. 85"
