Drag Racing Tech
Whos has tried these efi direct port nozzle systems?
Old 08-16-2006, 01:59 PM
FASTFATBOY's Avatar
Default Whos has tried these efi direct port nozzle systems?
Number one, Cold fusion kit, adjustable to 400 hp:
http://www.nitrousdirect.com/directportnitrouskit.html
Number 2, Nitrous express kit adjustable to 500hp:
http://store.summitracing.com/partde...ex-80010-10nxl
Number 3, NOS Noszle system, adjustable to 300 hp:
http://www.holley.com/08008NOS.asp
Thanks
Old 08-17-2006, 09:47 PM
MT POKT's Avatar
I'm using the NOSzles. I'm pretty happy w/ it! No drilling or tapping required.
Old 08-20-2006, 11:22 AM
captainwizbang's Avatar
I'm hunting for a direct port system as well and so far your #1 listing is looking good to me. I notice you did not list the ZEX setup. Any reason for it not making your list other than the ricer look?
Old 08-20-2006, 04:47 PM
FASTFATBOY's Avatar
Zex makes a similar system?
David
Old 08-21-2006, 07:23 AM
CatchinZs's Avatar
The NX kit look nice...I'm a big fan of the rail look.
That setup looks about as complete and clean as you can get but I think I would eventually upgrade to a braided lines just for the look.
Old 08-21-2006, 07:47 AM
OutlawZ's Avatar
fast, the nx kit on summit at the bottom description says GM models are adjustable only up to 180hp...... check that out before purchase cause even though they might give you jets for 500hp if the solenoid size won't flow 500hp worth of juice you just wasted some cash (assuming you wanted higher than 180hp)
Old 08-21-2006, 07:50 AM
CatchinZs's Avatar
That's a good point...I was just assuming that they gave you the jets for up to 180 but the kit could flow up to 500.
Man would I be pissed if I bought that kit to find that it would only flow 180 and had jets up to 500
Old 08-21-2006, 01:23 PM
Worm Boy's Avatar
I have used the Cold fusion kit on alot of friends cars. It works very well. I am also a dealer with them so let me know if you need to place an order.
Old 08-21-2006, 02:04 PM
FASTFATBOY's Avatar
Look at the part number I posted, It's adjustable to 500..I called NX.
David
Old 08-21-2006, 02:05 PM
FASTFATBOY's Avatar
The NX kit I listed doesn't come with rails, just a generic pic.
David
Old 08-21-2006, 02:27 PM
CatchinZs's Avatar
David
hmmm...
Directly from your link:
Nitrous does plug-and-play.
"Plug-and-play" isn't just for computers any more. Nitrous Express has brought the term to the car world with their NXL direct-port nitrous systems. There's no drilling or engine disassembly required, and there are no solenoids to mount. Everything for the system is contained in the high-flow fuel rail(s). There's even a special wiring harness, to make them genuine plug-and-play systems. Four-cylinder systems are selectable for 30, 60, or 90 HP increases, and versions for GM V8s are selectable for 80, 120, or 180 HP. The systems come complete with the nitrous bottle, insulated distribution lines, jets, wiring harness, and all mounting hardware.
Old 08-21-2006, 03:45 PM
FASTFATBOY's Avatar
hmmm...
Also a generic listing, look above it says jetting, 100, 200,300, 400, 500
I called NX on this kit it comes with NO rails, you use your efi rails and IS adjustable to 500 hp
Kit number : 80010-10nxl...search it on the web.
Any one used it?
David
Old 08-21-2006, 06:01 PM
FASTFATBOY's Avatar
Ferreday you have a PM
David
